What's Wrong with MakeMKV v2.0.0
UncannyGirl
Post by UncannyGirl »
For those who did not purchase the 4K UHD for "K-Pop Demon Hunters", you will likely encounter what seems like a corruption on the disc however despite dropping to below x0.1 speed it will continue to read. I did not want to risk my disc so I stopped the first attempt and checked if I was on the latest version of MakeMKV (as the last time I had any issues it was due to my software being older.)
The issue appeared to be with the disc as it's been my experience over the years when media discs are made to have translucent spots, read speeds drop like a tank. Usually not enough to cause it to skip in a player while watching but guaranteed back-ups will take double or more the time.
I typically go through the process of:
  • Create a Decrypted Backup
  • Create MKV files from that Back-Up
I still had a few decrypted Back-Up's waiting, however, now I had version v2.0.0.
Just like everyone said on the forum, I had to roll back to MakeMKV v1.18.4.
Why does v.2.0.0 crash shortly after this alert comes up, EVERYTIME with Decrypted Backups:
AACS directory not present, assuming unencrypted disc
Will this be fixed in the next version?
Re: What's Wrong with MakeMKV v2.0.0
Unfortunately, until the author Mike comes online and posts a fixed version, we don't know. The only thing we can recommend is sticking with 1.18 series, although 1.17 also works for most everything.
Bowi_QC
Post by Bowi_QC »
I'm just adding my two cents here to say that I'll be waiting for a new version. In the meantime, I changed my workflow.
