Simultaneous Disc ripping
BigMike63
#1 Post by BigMike63 » Sun Nov 22, 2026 4:36 pm
I've got two BD-ROM drives. And I am apple to rip for each simultaneously using MakeMKV 2.0. However, When one disc finished before the other and is ejected, the finished version of the program starts trying to read the other disc which is in the process of being ripped by the other instance of the program.
Is there a way to tell each instance of a MakeDVD session to ONLY look at a single drive and not whichever one has a disc loaded?
Re: Simultaneous Disc ripping
#2 Post by Woodstock » Sun Nov 22, 2026 11:35 pm
Start MakeMKV. Open the control menu, and go to the IO menu.
Check the box next to "Ask for single drive mode:"
Select OK.
Restart MakeMKV. You will be asked which drive to assign to this copy of MakeMKV.
I do not know if there is a limit to the number of running copies; I've run 4 copies AND used handbrake to to compress a copy at the same time, so it probably will handle as many copies as your machine can talk to drives.
