Hi everybody,
Been away from this forum for sometime. The last time I read was all Pioneer drives was on the verge of being enabled to rip 4K UHD Blurays. As I'm completely out of touch and I have 3 of these Pioneers onhand and also a UD04, please confirm the first 3 Pioneers are usable to rip 4K now without any firmware hacks. The details as below.
Info
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CHDL002774UC
Firmware date: 2022-12-27
Bus encryption flags: 18
Highest AACS version: 61
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID05
8D raw data read: Yes
UD04 no details to as not mounted as it's just a bare drive. What's the best way to mount it to use as a portable. Can a Verbatim portable drive casing meant for LG BU40N mount it as a sacrificial casing?
Another problem I have is one of the first 3 Pioneer drives, the USB C PCBA kaput after a short use for CD listening. Something in that PCBA completely short circuit as plug in USB C and power supply LED will dim. Don't dare to try further in case it short circuit my Pioneer drive further as surely the laser and motors are still brand new. Now I want a replacement USB C PCBA to service that drive. Anybody know where I can get a working donor USB C PCBA for that down drive of mine. Get in touch with me if have. Can post pictures of that kaput PCBA I'm writing about as no attachment button here.
I will discuss other things related to 4K video in other appropriate thread as this thread obviously is all about Pioneer things especially firmware upgrading or downgrading.
Thank for all the help coming. Cheerio!
Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
XTRProf
Re: Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
xd08u and ud04 should work stockXTRProf wrote: Tue Nov 10, 2026 10:46 am Hi everybody,
Info
OS device name: F:
Revision: 1.02
you can use the BU40n case on the ud04
XTRProf
Billycar11 wrote: Tue Nov 10, 2026 11:05 amxd08u and ud04 should work stockXTRProf wrote: Tue Nov 10, 2026 10:46 am Hi everybody,
Info
OS device name: F:
Revision: 1.02
Thanks. That's just great! Now to borrow a 4K Bluray to rip from the library if can find one. Normal Bluray easily found there.
the likely hood of a 4K disc from a library working for ripping is slim.XTRProf wrote: Tue Nov 10, 2026 10:02 pm
i cant tell you how many customers i had complain that "my junky drives cant rip discs from the library" but the issue is the damaged or dirty discs.
or another classic is the guy who did a charge back because my "junk drive needs a USB BOOSTER to work" mean while the issue is their low powered usb ports they sadly did end up getting that drive for free paypal does nothing for you with seller protection if they do a credit card charge back.
XTRProf
Billycar11 wrote: Wed Nov 11, 2026 2:17 amthe likely hood of a 4K disc from a library working for ripping is slim.XTRProf wrote: Tue Nov 10, 2026 10:02 pm
or another classic is the guy who did a charge back because my "junk drive needs a USB BOOSTER to work" mean while the issue is their low powered usb ports they sadly did end up getting that drive for free paypal does nothing for you with seller protection if they do a credit card charge back.![]()
Oh no! Chances of getting a 4K rippable Bluray from the library has just gone "Blawk Hawk Down"! I believed the same goes for the 4K Black Hawk Down Bluray if can be found at the library.
Really, I has always been wondering why those portable drives are nowadays all going for BUS power only. Really not very secure and on the border line. It must be with the old ways, power input as well as USB output. As I'm an Audiofool, I will not do that for the best sound when playing a CD or any Hirez discs from that portable drive.
Also, if you are burning a disc, why risk that and end up with a failed burn when not enough power is drawn and supplied to burn when needed? Writable Bluray discs are not cheap nowadays, you know. Throwing them away when failed burning will hurt everybody doing that.
Chong
Mr417
Thanks Billycar11 for your reply letting me know you have seen the particular drive I purchased not supporting being able to flashed.
Thanks Stefan2K22 for your reply letting me know you bought the same drive (x2) and that not all of the drives are ready out of the box and require flashing.
I specifically bought the drive to watch/rip 4K drives which it didn't so I sent it back and am having a new one shipped to me.
Hopefully it will recognize/read 4K discs out of the box like it's supposed to (fingers crossed).
If it doesn't I'll reach out to the selling vendor for a third & final time to try and get an actual 4K drive.
Then if that doesn't work then I'll research drives again and buy a complete different one.
FYI: The darn newer system I'm now using to rip my BR/4K discs doesn't have an internal drive slot so I'm forced to use an external drive via USB3 or USB-C
Luickly I've got a internal BR drive I'll eventually get transferred into an external case and then flashed to use as a backup though.
Hobbles
I have an HL-DT-ST BU40N running CB05 firmware (MT1959 platform), connected via a USB 3.0 slimline enclosure on macOS.
MakeMKV detects the drive, but LibreDrive reports "Possible, not yet enabled."
Drive ID: HL-DT-ST_BD-RE_BU40N_CB05_211711291351
I'm planning to flash BU40N 1.03-MK using makemkvcon without the `enc` flag. The drive is already installed in an enclosure that's difficult to disassemble, so I can't easily check the manufacturing date on its label. Is there a reliable way to confirm this particular BU40N is safe to flash without removing it?
The fw date in makemkv is what to go by looks like 2017 so no enc is rightHobbles wrote: Mon Nov 16, 2026 2:23 pm I have an HL-DT-ST BU40N running CB05 firmware (MT1959 platform), connected via a USB 3.0 slimline enclosure on macOS.
raydyo
Total newb here. Forgive me if I am violating any etiquette. I was looking to buy the JOTEC drive talked about in this thread, but it was a few weeks out on amazon. Being impatient I took a shot at this look-alike with 2-day prime shipping.
https://www.amazon.com/dp/B0GVNL4WGW?re ... asin_title
It appears to be good to go out of the box:
Product: BD-RE BU40N
Revision: BU10
Serial number: KZFH5JE2900
Firmware date: 2117-01-06 09:41
Bus encryption flags: 1F
Highest AACS version: 63
Firmware version: 0.BU10O
Disc Information
Label: THE_WINERY_DOGS
Timestamp: 2017-05-24 15:53:24
Protection: AACS v63
Data capacity: 22.58 Gb
Disc type: BD-ROM
Number of layers: 1
Revision: BU10
Disc Information
Disc type: BD-ROM
Number of layers: 1
zaybdr
I recently acquired a used BDR-208XJK; is it possible to make it compatible with UHD?
Here are the specs from makemkv:
OS device name: E:
Product: BD-RW BDR-208M
Revision: 1.40
Serial number: ***********
Firmware date: 2014-03-06
Highest AACS version: 82
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.40
OS device name: E:
Revision: 1.40
