Feature Idea: Decrypted Mount
My1xT
Post by My1xT »
quite simple as an idea: most Laptops and stuff dont have a BD Drive available (to no one's surprise) but you might have another PC or a headless server or a mini-server based NAS that has space for a drive. one thing that would be fairly neat would be an option to expose a decrypted virtual drive (be it a mounted folder on Linux/Mac or a virtual Drive in Windows) that gets populated with virtual files that correspond to the decrypted Metadata of whatever is on the bluray, and the video/audio files would only need to be decrypted live in RAM or something when a program is trying to access them.
that way you wouldnt need to fully rip the discs but just could watch whatever is in that PC/Server/NAS/whatever from any device that does read decrypted blurays.
tomty89
Re: Feature Idea: Decrypted Mount
Post by tomty89 »
Kinda doubt that MakeMKV will get any new feature.
Btw freemkv somewhat allows "host" a drive on one machine and "connect" to it (with freemkv) from another. The "client" freemkv can then convert the disc to an mkv and write it to stdout, which you might be able play with some player (probably no seeking though?).
FWIW, I think you can totally expose a drive through iSCSI, and libmmbd / libaacs should be able read from it on a client and decrypt the content. (Even things like LibreDrive hacks should work since they are done through SCSI commands as well.) But you may already know that.
