Non-Forced Subs Not being removed
Sandriell
Post by Sandriell » Wed Jun 06, 2012 6:18 am
As the subject says, non-forced subs are not being removed from the output file.
Chetwood
Re: Non-Forced Subs Not being removed
Post by Chetwood » Wed Jun 06, 2012 7:22 am
Why should non-forced subs be removed? Forced subs are removed when it turns out that the stream is empty. Which appears to be what happened with your rip. IDs 3 and 5 are the regular subtitle tracks and the corresponding forced streams where removed so you end up with two regular sub streams.
Sandriell
Post by Sandriell » Wed Jun 06, 2012 4:34 pm
Then I guess I misunderstood how the "Forced Only" checkbox is supposed to work. I thought if the subs turned out to not be Forced, they were not included at all.
paulster
Post by paulster » Wed Jun 06, 2012 6:54 pm
You can check the 'Forced' box without the corresponding (underlying) subtitle stream so you'll only get the forced track if it isn't empty, if that's what you're trying to achieve.
Sandriell
Post by Sandriell » Sat Jun 09, 2012 2:22 am
paulster wrote:You can check the 'Forced' box without the corresponding (underlying) subtitle stream so you'll only get the forced track if it isn't empty, if that's what you're trying to achieve.
Ah, so I don't need to select the parent checkbox, just pick "Forced Only".
Thanks.
