Similar issues here with 2.0.0 on both Windows and Linux.
1. Unable to open backup folder of UHD disc (created by earlier version of MakeMKV) with MakeMKV 2.0.0, however the same folder could be opened by MakeMKV 1.18.4
2. Unable to open backup folder of UHD disc (created by MakeMKV 2.0.0) with MakeMKV 2.0.0, however the same folder could be opened by MakeMKV 1.18.4
Version 2.0.0 won't open the disk structure (bug?)
leaflet
EthanBB
Re: Version 2.0.0 won't open the disk structure (bug?)
I had the same problem with both UHD and Normal Bluray (Kpop Demon Hunters - Criterion), dumping went fine but then opening, gave the error and exited the program on 2.0.0, after downgrading to 1.18.4 muxing to MKVs worked fine. (I did NOT have to re-dump the discs)
