Drive reports LibreDrive as working, but every Blu-ray fails AACS authentication and ends with “Can’t read AACS VID from disc — most likely current AACS host certificate is revoked by your drive”.
Drive info:
Product: ASUS SBW-06D5H-U, Revision E102
Firmware date: 2023-04-20
LibreDrive Status: Enabled
Drive platform: RS8511
Firmware version: E102/ID26
DVD all regions: Yes, BD raw data read: Yes, BD raw metadata read: Yes
MakeMKV v2.0.0, tested on both Windows 11 and Linux (Docker container on Unraid) — identical behaviour on both. Hundreds of COPY PROTECTION KEY EXCHANGE FAILURE — KEY NOT ESTABLISHED before it gives up and downloads a new HK.
My question: if LibreDrive is enabled and BD raw data read is supported, why is MakeMKV falling back to AACS host authentication at all? Is this a known limitation of the RS8511/BDR-US03 platform, and would patched firmware resolve it?
ASUS SBW-06D5H-U (Pioneer BDR-US03, RS8511) — LibreDrive Enabled but AACS host certificate revoked
Paetli
Yethidran
Re: ASUS SBW-06D5H-U (Pioneer BDR-US03, RS8511) — LibreDrive Enabled but AACS host certificate revoked
guess its best to revert back to MakeMKV version 1.84, instead of using MakeMKV version 2.00. (Marty has said pretty often that version 2.00 is very buggy.)
Yethidran
i also wonder if you have flashed your drive to be "UHD Capable"?
quite a few people in this forum already can give you "Totally Free Firmware's"
only one still charges for firmware to this day.
You should flash that drive see guide below or email me for an automated flasherPaetli wrote: Mon Nov 09, 2026 4:14 pm Drive reports LibreDrive as working, but every Blu-ray fails AACS authentication and ends with “Can’t read AACS VID from disc — most likely current AACS host certificate is revoked by your drive”.
Drive info:
