Proper firmware for BU50N
harryshuman
#1 Post by harryshuman » Mon Nov 09, 2026 7:58 am
I got this new BU50N Drive with the following info provided by MakeMVK:
OS device name: E:
Product: BD-RE BU50N
Revision: CC04
Serial number: 103HS030502
Firmware date: 2120-05-29 09:18
Bus encryption flags: 1F
Highest AACS version: 82
I attempted to flash it using version 1.00 firmware I found, but it throws an error 0x82052603. I couldn't find any other firmware for it, but I see people online mention BU50N is similar to BU40N.
Which firmware should I use to bypass the error?
Re: Proper firmware for BU50N
#2 Post by Billycar11 » Mon Nov 09, 2026 8:05 am
harryshuman wrote: Mon Nov 09, 2026 7:58 am Hello,
OS device name: E:
Revision: CC04
follow the guide for BU40N
if you want an auto flasher email me or marty for one
see below for email
harryshuman
#3 Post by harryshuman » Mon Nov 09, 2026 9:29 am
Thanks, I used the BU40N 1.03 firmware file and it worked like a charm (it's my second drive). I just didn't know whether BU50N was any different.
Out of curiosity, is there any benefit to flashing the drive to 1.00 firmware after 1.03 or can it just stay at 1.03?
#4 Post by Billycar11 » Mon Nov 09, 2026 10:43 am
harryshuman wrote: Mon Nov 09, 2026 9:29 am Thanks, I used the BU40N 1.03 firmware file and it worked like a charm (it's my second drive). I just didn't know whether BU50N was any different.
1.00 works with other rippers
but if you use makemkv no point really
