Main feature skipped due to a navigation error – Jet Li’s Fearless DVD
Knuddel7382
Post by Knuddel7382 » Sun Nov 08, 2026 5:35 pm
Hi everyone,
I’m having a problem with the DVD Jet Li’s Fearless. The main feature does not appear as a title I can rip. MakeMKV detects it as Title #2 (1:39:25), but skips it because of a navigation error.
Here is the log from the scan:
MakeMKV v2.0.0 linux(x64-release) started
udf: UDF: BROKEN DIRECTORY ENTRY
Using LibreDrive mode (v06.3 id=8B0DAADF6310)
Direct access mode is being used
Calculated BUP offset for VTS #0 does not match the one in the IFO header
Calculated BUP offset for VTS #1 does not match the one in the IFO header
Calculated BUP offset for VTS #2 does not match the one in the IFO header
Calculated BUP offset for VTS #3 does not match the one in the IFO header
Calculated BUP offset for VTS #4 does not match the one in the IFO header
Calculated BUP offset for VTS #5 does not match the one in the IFO header
Calculated BUP offset for VTS #6 does not match the one in the IFO header
Calculated BUP offset for VTS #7 does not match the one in the IFO header
Calculated BUP offset for VTS #8 does not match the one in the IFO header
Calculated BUP offset for VTS #9 does not match the one in the IFO header
Calculated BUP offset for VTS #10 does not match the one in the IFO header
Calculated TVOB offset for VTS #2 does not match the one in the IFO header
Calculated MVOB offset for VTS #0 does not match the one in the IFO header
Calculated TVOB offset for VTS #3 does not match the one in the IFO header
Calculated TVOB offset for VTS #1 does not match the one in the IFO header
Calculated MVOB offset for VTS #1 does not match the one in the IFO header
Calculated TVOB offset for VTS #4 does not match the one in the IFO header
Calculated MVOB offset for VTS #5 does not match the one in the IFO header
Calculated TVOB offset for VTS #5 does not match the one in the IFO header
Calculated MVOB offset for VTS #6 does not match the one in the IFO header
Calculated TVOB offset for VTS #6 does not match the one in the IFO header
Calculated TVOB offset for VTS #8 does not match the one in the IFO header
Calculated MVOB offset for VTS #7 does not match the one in the IFO header
Calculated TVOB offset for VTS #9 does not match the one in the IFO header
Calculated TVOB offset for VTS #7 does not match the one in the IFO header
Cells 1-1 were removed from the start of the title
Title #2 (1:39:25) was skipped due to a navigation error
Title #2/1 has a length of 70 seconds and was skipped because the minimum title length is 120 seconds
Title #4 has a length of 4 seconds and was skipped because the minimum title length is 120 seconds
Title #5 has a length of 18 seconds and was skipped because the minimum title length is 120 seconds
Title #6 has a length of 5 seconds and was skipped because the minimum title length is 120 seconds
Title #7 was added (2 cell(s), 0:02:21)
Title #9 has a length of 11 seconds and was skipped because the minimum title length is 120 seconds
Title #10 has a length of 20 seconds and was skipped because the minimum title length is 120 seconds
Title #11 was added (3 cell(s), 0:16:04)
Title #12 was added (2 cell(s), 0:08:00)
Title #13 was added (4 cell(s), 0:02:32)
Title #14 has a length of 105 seconds and was skipped because the minimum title length is 120 seconds
Title #15 has a length of 38 seconds and was skipped because the minimum title length is 120 seconds
Title #16 has a length of 87 seconds and was skipped because the minimum title length is 120 seconds
Title #18 was added (2 cell(s), 0:02:08)
Title #19 has a length of 107 seconds and was skipped because the minimum title length is 120 seconds
Title #20 was added (2 cell(s), 0:02:30)
Title #21 has a length of 117 seconds and was skipped because the minimum title length is 120 seconds
Title #22 has a length of 16 seconds and was skipped because the minimum title length is 120 seconds
Title #23 has a length of 90 seconds and was skipped because the minimum title length is 120 seconds
Title #24 has a length of 11 seconds and was skipped because the minimum title length is 120 seconds
Title #25 was added (2 cell(s), 0:02:35)
Title #26 (0:02:58) was skipped due to a navigation error
The operation completed successfully
Has anyone encountered this with this DVD or a similar one? Is there a way to get MakeMKV to recognize or process the main feature, or do these messages point to a problem with the disc?
