Issue with Random BluRay Disks and Possible LibreDrive Enablement
elevenapple
#1 Post by elevenapple » Sat Nov 07, 2026 1:08 pm
I am getting odd errors on 3 specific bluray disks but not others and I did not know if it had anything to do with flashing.
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: MOEP6484302
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 82
Disc Information
Disc is being loaded
Re: Issue with Random BluRay Disks and Possible LibreDrive Enablement
#2 Post by Billycar11 » Sat Nov 07, 2026 2:07 pm
What would those errors be?
It is likly the discs clean them
elevenapple
#3 Post by elevenapple » Sat Nov 07, 2026 2:18 pm
I have tried cleaning it and looking at it I see no blemishes or issues. The errors on one particular disk seem to be:
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/01218.m2ts' at offset '29898571776'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '29898571776'
#4 Post by Billycar11 » Sat Nov 07, 2026 2:29 pm
See why it's important to post error
Now it looks like a power issue with your USB ports use higher power one or get a powered USB hub
elevenapple
#5 Post by elevenapple » Sat Nov 07, 2026 2:44 pm
Thanks, I appreciate the response.
I'm using a usb powered usb hub but I may try a different one. I tried a 2nd bluray that I keep getting errors on and this is what I got
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '5222037504'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01156.m2ts' at offset '5222037504'
#6 Post by MartyMcNuts » Sun Nov 08, 2026 12:02 am
elevenapple wrote: Sat Nov 07, 2026 2:44 pm Thanks, I appreciate the response.
Not a USB powered hub. Must be an AC powered hub or use USB 3+ or USB-C ports direct from the motherboard (not case ports).
gwhitcombe71
#7 Post by gwhitcombe71 » Mon Nov 09, 2026 11:54 pm
MartyMcNuts wrote:Not a USB powered hub. Must be an AC powered hub or use USB 3+ or USB-C ports direct from the motherboard (not case ports).
MartyMcNuts is right on that, for what it's worth... USB-powered hubs just dont give a bluray drive enough juice when the laser has to work harder on a dodgy read. had the exact same symptoms on my own setup, swapped to a port straight off the board and the I/O errors stopped.
