3D Bluray
firionicable
Re: 3D Bluray
They can retain HD video quality, but not sure if it is applicable in 3D videos...
Re: 3D Bluray
Current versions retain all 3D information when doing a full disc backup.
The next version will have an option to put 3D MVC extension stream into MKV file. The MVC extension stream is related to AVC stream very similarly to what DTS-HD is to DTS stream - most players initially will ignore MVC extension and only play 2D "core".
anbrey
Re: 3D Bluray
Thanks. Just to make that clear: in other words it means that the files won't play 3D. But why then should I want to create these files? For what purpose create them?mike admin wrote:Current versions retain all 3D information when doing a full disc backup.
crowfax
Re: 3D Bluray
It means that is the player supports 3D it'll play in 3D, and if the player does not support 3D, it'll play in 2D.anbrey wrote:But why then should I want to create these files? For what purpose create them?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
Romansh
Re: 3D Bluray
So that you don't need to re-rip your disc when your favorite player implements support for it.anbrey wrote:Thanks. Just to make that clear: in other words it means that the files won't play 3D. But why then should I want to create these files? For what purpose create them?mike admin wrote:Current versions retain all 3D information when doing a full disc backup.
Chiasmos
Re: 3D Bluray
Thanks mike.mike admin wrote:Current versions retain all 3D information when doing a full disc backup.
We'll await your next version and move forward with the 3D from there.
insx72
Re: 3D Bluray
I'm really confused about this. Could someone explain simply what MakeMKV does and doesn't do with a 3D blu ray? I read posts from 2 years ago saying that a 3D file can be created. Can I play this with Bino?
Re: 3D Bluray
Current version of MakeMKV:
- preserves all 3D data during backup
- Can create a MKV file with 3D MVC video stream. Presently there are very few players that can play such MKV file, but all the data is there.
Marsik
Re: 3D Bluray
Mike, could you please name some players capable of playing such 3D MVC files.
Thank you!
Thank you!
pash43uk
Re: 3D Bluray
Help - ive tried converting the 3D video from several isos but they only play in 2D on my mede8er 600 , am i doing something wrong ?
patseguin
Re: 3D Bluray
I use XBMC and it doesn't support playing 3D ISO's or MVC's. I'm wondering if this next version will create a file that will play in 3D on XBMC (Gotham).
trumpet205
Re: 3D Bluray
XBMC cannot and will not in foreseeable future open 3D MVC format used in 3D Blu-ray.
The best you can do is putting together an Avisynth script to re-encode the movie into H-SBS/H-TAB. MakeMKV is a ripper. It will NEVER re-encode the video.
Re: 3D Bluray
With hardware decoding it can, at least on proper NVIDIA cards.trumpet205 wrote:XBMC cannot and will not in foreseeable future open 3D MVC format used in 3D Blu-ray.
