Thank you for your order! Regarding your concerns about maintenance: because these are New Old Stock (NOS), the internal belts and factory lubricants haven't been subjected to years of operational heat and dust, so they generally hold up exceptionally well. We have customers using it for months now with over 1000 rips.inflationstation wrote: Mon Nov 02, 2026 5:32 pm I have purchased a drive and will update when it arrives. Looks like it was shipped out recently and will arrive to Canada by the end of the week which is quite fast.
I used the upfront option (DDP?) to hopefully cover the taxes/import tariffs. Never used that before but I assume FedEx did the calculations correctly on their end to ensure no payments will be needed at delivery. I believe for Canadians this is likely cheaper than the fees they would charge after the fact (broker fees for FedEx and other private couriers is usually as much as the tax itself or more).
My biggest concern is likely to be things I can maintenance myself (like dried out lubricant on moving internal parts, or replacing rubber tray belts). Otherwise I'm pretty confident I will be happy when it arrives.
I will update after receiving. Initially I was trying to source drives through Ebay but the amount of counterfeits/relabelled/rebadged drives are nearly impossible to filter out at this point. I found some encouraging listings from Japanese sellers, but of course then found many highly rated Japanese based sellers are also now selling drives with duplicate labels and serial numbers across multiple models, and they all claim they are "100% authentic". Seems there is no good way to ensure you aren't getting counterfeits on Ebay, so at least with this you can be sure you are receiving an authentic Pioneer drive.
Glad to hear the BDR-209DBK is running quietly and ripping well for you. Sorry to hear you got hit with that $50 import tax on arrival—US customs can unfortunately be a bit of a roulette wheel depending on the agent processing the package.pashdown wrote: Wed Nov 04, 2026 9:14 pm Thumbs up on the purchase of Pioneer BDR-209DBK. I did have to pay a $50 Trump Tax on arrival. I was also confused because it didn't present the same model number in MakeMKV, but this is due to it already being flashed and ready for ripping. It tops at 4x and is very quiet. I'm happy with my purchase and their responsiveness to support requests.
Wow, thank you for such an incredibly detailed and thoughtful review! Your experience with the triple-layer BD100 discs perfectly highlights why the community loves these Pioneer drives so much. The older ASUS/LG drives are great for standard Blu-rays, but Pioneer's optics handle those difficult layer transitions on 4K discs with so much more stability.gsingle wrote: Wed Nov 04, 2026 10:37 pm I purchased a Pioneer BDR-S08XLT from UHD Archive, and after ripping more than 40 4K UHD discs, I can confidently say this has been one of the best upgrades I've made to my movie-ripping setup.
For context, I previously used an ASUS BW-16D1X-U external Blu-ray drive, flashed with LibreDrive-compatible firmware. It performed exceptionally well with DVDs and standard Blu-rays, ripping them quickly and reliably. However, 4K UHD discs were another story.
My ASUS/LG drive successfully ripped perhaps 60% of my UHD collection, and even some of those required multiple attempts. It struggled particularly with triple-layer (BD100) discs, frequently encountering hash-check errors and read failures, often around layer transitions. I also suspected thermal sensitivity, as the drive would sometimes require an overnight cooldown before I could successfully retry a problematic disc. On particularly difficult titles, I had to resort to creating backups and using MKVToolNix as a workaround. It became a frustrating and time-consuming process.
Enter the Pioneer BDR-S08XLT from UHD Archive. The difference has been remarkable.
I've now ripped more than 40 4K UHD movies, including numerous triple-layer discs, without a single read error or failed rip. More impressively, every disc that previously gave my ASUS/LG drive trouble has ripped successfully on the Pioneer on the very first attempt.
A few things that have particularly impressed me:
- Exceptional UHD reliability: Every 4K UHD disc I've tried has ripped successfully, including troublesome BD100 titles.
- No cooldown periods: I can rip multiple 4K movies back-to-back without worrying about the drive overheating or becoming unreliable.
- No workarounds necessary: I haven't needed to use the backup method or MKVToolNix to recover a problematic rip.
- Extremely quiet operation: The Pioneer is noticeably quieter than my previous ASUS/LG drive. The difference is substantial.
- Consistent performance: Maximum UHD read speeds peak at around 4X, with a typical 4K movie taking approximately 60 minutes to rip directly to MKV using MakeMKV. I'll gladly take that level of reliability over faster speeds and repeated failures.
Purchasing Experience - Excellent
I'm located in the United States and purchased directly through UHD Archive's website rather than eBay. I did not prepay VAT or import taxes.
My order arrived within just seven calendar days from Turkey, which was genuinely impressive.
The drive arrived in like-new condition. Despite being manufactured in 2013, there was no visible rust, corrosion, or damage to the external casing. The original retail box was intact, although some of the adhesive had weakened with age, exactly as the seller discloses on their website.
Given that UHD Archive prepares these older drives with UHD-compatible firmware before shipping, I expected some evidence of handling. Nevertheless, the drive looked excellent and has performed flawlessly.
Final Thoughts
I finally understand why there are so many passionate Pioneer enthusiasts in the UHD ripping community. These drives really are that good, particularly when it comes to reliably reading difficult 4K UHD Blu-ray discs.
After dealing with countless failed rips, repeated retries, cooldown periods, and complicated workarounds, having a drive that simply works every single time has been a game changer.
I highly recommend both UHD Archive as a seller and the Pioneer BDR-S08XLT to anyone serious about archiving a 4K UHD collection. The product condition, shipping experience, and most importantly, actual performance have exceeded my expectations.
And a special thank you to UHD Archive for sourcing, preparing, and bringing these new-old-stock Pioneer drives back to life. It's great to see such outstanding hardware being made available to enthusiasts who can genuinely appreciate it.
Absolutely worth the investment. Highly recommended!
I have put a lot of effort into tracking down, testing, and flashing these drives, and reading a review like yours makes every bit of that work completely worth it.
