Set all components to be not ticked?
Z0001
Post by Z0001 » Sat May 26, 2012 6:58 pm
Is it possible to set by default all the video, audio and subtitle streams to be not ticked rather than ticked. Helpful as I am only including a minimum in my process.
Z
Smithcraft
Re: Set all components to be not ticked?
Post by Smithcraft » Sat May 26, 2012 8:05 pm
I don't think this option exists in MakeMKV, but I would like to see this as an option.
You can right click on the stream selections and Unselect All, then select what you want.
SC
Post by mike admin » Wed May 30, 2012 7:42 pm
Yes, you can. See "default selection rule" in advanced preferences. It's explained in detail in "advanced MakeMKV usage" subforum.
Smithcraft
Post by Smithcraft » Fri Jun 01, 2012 1:50 am
So, that would be this setting "-sel:all" correct?
SC
MilesAhead
Post by MilesAhead » Sat Jun 02, 2012 8:47 pm
mike admin wrote:Yes, you can. See "default selection rule" in advanced preferences. It's explained in detail in "advanced MakeMKV usage" subforum.
I don't see any explanation how to get to "advanced preferences". All I have is a Preferences dialog. Nothing on any of the tabs uses the word "advanced" that I can see. Is there an Easter Egg?
MakeMKV v1.7.4 win(x86-release) started
Romansh
Post by Romansh » Sat Jun 02, 2012 10:33 pm
There's an "Advanced" tab in Preferences. It's the last/rightmost tab, but you have to enable expert mode ("General" tab) to see it.
MilesAhead
Post by MilesAhead » Sun Jun 03, 2012 2:15 am
Got it. Thanks :)
