Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Evil_Crab
Re: THIS!
Post by Evil_Crab »
jwagner wrote: Sun Oct 11, 2026 9:21 pm Hey everyone I wanted to post this on the forum to let everyone know that there is an affordable slim 4K Blu-ray optical drive that has a factory firmware that works out of the box with MakeMKV. I tested it with 4K, Blu-Ray and standard DVDs last night and it works successfully without any firmware modification.
https://www.amazon.com/dp/B0H1HNDPCL?re ... asin_title
IF the link doesn't work you can search for the title "JOTEC Premium Aluminum 4K UHD External Blu-Ray Drive
4K Blu-ray Burner, USB 3.0 & Type C Dual Interface, Compatible with All PC & Mac Models, Support 100GB 128GB"
The manufacturer ships both BU40N BU50N models. It retails for $142.99
Thank you for the info! I tried my luck with the similar-looking drive available in Europe (https://www.amazon.nl/dp/B08PFMVSNW?ref ... asin_title) and I can confirm that it also works out of the box.
OS device name: E:
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO9Q3AA4607
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
sjordi
Re: Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Post by sjordi »
So what do we do with U102?
Apparently they're encrypted and difficult. I read the guide but am not sure what to do with this specific drive...
Do I go normally with firmware 1.03 and that's it?
Any link? Thanks
sjordi wrote: Mon Nov 02, 2026 9:23 pm So what do we do with U102?
Any link? Thanks
Email me or Marty for an automated flasher if your unsure what fw to use see email below
sjordi
Post by sjordi »
Ok thanks,
Obviously, I'm not allowed to send private messages
Revision: U102
Serial number: MO3JCO42325
Firmware date: 2119-05-10 13:19
Bus encryption flags: 1F
Highest AACS version: 81
Mr417
Re: THIS!
Post by Mr417 »
@jwagner
I just wanted to let you know per your posts recommendation I purchased the drive you got [https://www.amazon.com/JOTEC-Aluminum-E ... B0H1HNDPCL] which worked out of box with MakeMKV to read/rip 4K discs for you however, the one I got sent doesn't doesn't read 4K discs (doesn't see the disc in the drive but it tried to read it) nor does MakMKV recognize a 4K disc in it (it sees/plays & rip BR's with MakeMKV though) .
Here is MakeMKV's read out of the drive I received with a Blue Ray Disc loaded:
OS device name: E:
Revision: CB04
Serial number: [Truncated]
Firmware date: 2117-05-18 20:12
Highest AACS version: 82
Disc Information
Label: THE_MANDALORIAN_AND_GROGU
Timestamp: 2026-07-15 15:47:48
Protection: AACS v82
Data capacity: 44.99 Gb
Disc type: BD-ROM
Number of layers: 2
My question to you is there a setting you changed or a simple flash process you did to the drive to get it to recognize 4K disc's and have MakeMKV recognize it?
I wanted to ask before I sent it back for another one with the thinking they accidentally shipped me just a Blue-Ray disc player and not a 4K one like what I supposedly ordered.
Thanks in advance for your response
Mr. 417
In my case it handshakes with the MakeMKV status message of-
OS device name: /dev/rdisk4
Revision: FR07
Serial number: XXXXXXXXXXX
Firmware date: 2116-12-20 16:51
Firmware version: 0.FR07J
Re: THIS!
Mr417 wrote: Wed Nov 04, 2026 6:33 pm @jwagner
OS device name: E:
Revision: CB04
Disc Information
Disc type: BD-ROM
Number of layers: 2
Mr. 417
Revision: FR07
I have seen that drive case many times not support flashing
sjordi
Post by sjordi »
sjordi wrote: Tue Nov 03, 2026 3:53 am Ok thanks,
Revision: U102
Any way you DM me?
Stefan2k22
Re: THIS!
Post by Stefan2k22 »
OS device name: E:
Revision: CB04
Disc Information
Disc type: BD-ROM
Number of layers: 2
Mr. 417
Revision: FR07
In my prior post in this thread I think I accidentally quoted the wrong comment. Anyway, this is the same drive I bought. I actually got 2. Anyway, apparently not all of the drives are ready right out of box as some people reported. It probably depends on the firmware revision you just happen to get. Anyway, following the instructions of Mr_Orange and Billycar11, I was able flash the 1.03mk firmware and make them both work. So, you probably need to do the same. Thanks to both Mr_Orange and Billycar11 for pointing me in the right direction.
sjordi wrote: Thu Nov 05, 2026 1:43 am
Revision: U102
Any way you DM me?
thats why my email is below to avoid the dm issue...
