MKV skipping subtitles-
kjempebaby
Post by kjempebaby » Sat Jun 02, 2012 2:47 pm
Having issue with old DVD 4:3 movies. (mac)
I used DVD FAB to copy full DVD. ISO and DVD Folder (AUDIO_TS/VIDEO_TS folder).
Then I used Mydvdedit to change movie/DVD from 4:3 to 16:9.
http://www.mydvdedit.com/viewtutorial.p ... e&pg=forum
From DVD With Makemkv it shows all Subtitles-DVD is 4:3:-(
From Iso and my DVD folder (16:9) Makemkv is skipping the subtitles???? Why??? Tried several times........
DVD folder and ISO shows subtitles in VLC and Handbrake. Works great. So I want to add this in MKV container
Seems like Makemkv are skipping all the subtitles streams I want. I only get the English subtitles. (first track?)
Is the an options for "don?t skip track-advandced menu?
Have also tried to delete subtitles with Mydvdedit, no luck.
The reason for this prosses is changing the movie and subtitles to 16:9 (Keeping original quality) as MKV.
Please help!
From the ISO file
From the ISO file
From AUDIO_TS/VIDEO_TS folder local
This is options from DVD
Smithcraft
Re: MKV skipping subtitles-
Post by Smithcraft » Sat Jun 02, 2012 7:44 pm
What DVDs, what region, what version of MakeMKV?
SC
kjempebaby
Post by kjempebaby » Sat Jun 02, 2012 8:42 pm
Chip 'N?Dale Rescue Rangers Volum 1-
http://cdon.no/film/snipp_%26_snapp%3a_ ... ._1-747481
Region 2
Makemkv V1.7.4
Hope there will been a choice on Makemkv with 4:3 movies, checkbox to make as 16:9
Then I wouldn?t have to use time with mydvdedit
(I understand windows use Dvdpatcer - http://www.videohelp.com/tools/DVDPatcher
Would be great with this integrated....I can only hope :D
Smithcraft
Post by Smithcraft » Sun Jun 03, 2012 8:37 am
Perhaps try ripping the disc directly with MakeMKV, then use the Header Editor feature in mkvtoolnix to change the aspect ratio to 16 by 9, instead of the messing around with the ifos for the DVDs.
SC
kjempebaby
Post by kjempebaby » Sun Jun 03, 2012 11:08 am
Didn?t have any luck with aspect ratio fix with mkvtoolnix. Long story.....
