ASUS BW-16D1X-U (A105, MT1959): makemkvcon spins at 100% CPU at “Scanning CD-ROM devices” when a disc is inserted
Snare7479
#1 Post by Snare7479 » Sun Nov 01, 2026 10:06 am
I’m setting up an automatic ripper on Linux. My new ASUS BW-16D1X-U hangs in makemkvcon as soon as a disc is in the drive. The same drive and discs work fine on Windows.
Setup
  • Drive: ASUS BW-16D1X-U, firmware A105 (MediaTek MT1959), external with its own power supply, connected over USB (usb-storage)
  • Host: Intel NUC, Ubuntu Server 26.04
  • makemkvcon 1.18.4 (ARM Docker image) and 2.0.0 (jlesage/makemkv image). The behaviour is identical in both.
What happens
  • With an empty drive, makemkvcon -r info disc:9999 lists the drive within seconds.
  • With any DVD inserted (tested with 3 different discs), makemkvcon -r --progress=-same info dev:/dev/sr0 stops at “Scanning CD-ROM devices” and never continues. I’ve left it running for 9 hours.
  • One makemkvcon thread runs at ~99% CPU in userspace (state R), and the other threads sleep. Nothing is blocked on I/O.
  • It also hangs with networking disabled (docker run --network none).
  • Meanwhile the drive responds normally to SCSI commands from Linux: sg_inq works, and TEST UNIT READY returns Good.
  • The same drive and DVDs on Windows with MakeMKV 2.0.0 work without problems: “Using direct disc access mode”, and all titles are listed.
Debug log (--debug), ends here:
MakeMKV v1.18.4 linux(x64-release) started
Debug logging enabled
Network access is ENABLED, CURL version 7.81.0/OpenSSL/3.0.2/1.43.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at KG]XmhY0,A.yRLL3a@B-s>:29393631
No  SDF v0a6: ASUS_BW-16D1X-U_A105_212012021114_KLGPBJF5132
SDF auto v0a6: ASUS_BW-16D1X-U_A105_212012021114_KLGPBJF5132
Already ruled out
  • USB disconnects: on USB 3 the drive kept resetting while udev/blkid probed the CSS disc. A udev rule that skips blkid on sr* fixed that, and the drive is stable now. makemkvcon still hangs.
  • Permissions: running makemkvcon as root gives the same result.
  • Docker: both privileged and non-privileged containers give the same result.
Is there a setting, or an SDF file for this firmware, that avoids the hang on Linux? I’m happy to run more tests or send the full debug log.
Re: ASUS BW-16D1X-U (A105, MT1959): makemkvcon spins at 100% CPU at “Scanning CD-ROM devices” when a disc is inserted
#2 Post by 16442496 » Tue Nov 03, 2026 6:45 pm
Did you try this:
"not reading bluray (but on windows yes)"
viewtopic.php?p=203364#p203364
MakeMKV 1.17.6
+ gddrescue
Snare7479
#3 Post by Snare7479 » Wed Nov 04, 2026 6:55 pm
16442496 wrote: Tue Nov 03, 2026 6:45 pm Did you try this:
No I didn't and now it is working! Thank you! Quite the easy fix :D
