Is there a way to "fix" Asus BW-16D1HT 3.10 to tip triple layers again or is it dead due to wear & tear over the years?
JediFonger
Post by JediFonger » Mon Nov 02, 2026 5:08 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.10
^the last triple layer i was able to rip was Shane 4k (kino) and i think Minions & Monsters 4k. before that, i've had strange behaviors where the drive wouldnt read triple layer and my workaround has always been to poweroff machine, unplug electricity and press and hold power button to discharge then turn it back on. or just a simple reboot would often do it, but unfortunately for almost a month now i haven't been able to read any triple layer. hd66 dual works fine, just not triples. i've reflashed 3.10 multiple times thinkin that would "jumpstar" this.
any other things you think i should try? should i try 3.11 or flash it with other types of fw? the logs don't show anything because right off the bat the drive can't read the triple layer discs. all i get from makemkv is "no disc inserted". is this the last hurrah and should i just save up some $ and try to buy another drive like a pioneer?
Re: Is there a way to "fix" Asus BW-16D1HT 3.10 to tip triple layers again or is it dead due to wear & tear over the yea
Post by Coopervid » Mon Nov 02, 2026 5:33 pm
Generally LG WH16NS60 1.02 is better for triple layer discs and reading them in. Flash it. You hould also consider to clean the laser lens. Buy a CD cleaning disc.
JediFonger
Post by JediFonger » Tue Nov 03, 2026 4:55 am
just used my cleaner. didnt work, issue remains
Post by Coopervid » Tue Nov 03, 2026 10:49 am
JediFonger wrote: Tue Nov 03, 2026 4:55 am just used my cleaner. didnt work, issue remains
Flash WH16NS60 1.02.
JediFonger
Post by JediFonger » Tue Nov 03, 2026 7:02 pm
Coopervid wrote: Tue Nov 03, 2026 10:49 am
LG fw works on asus?
JediFonger
Post by JediFonger » Tue Nov 03, 2026 9:35 pm
command produced error code 0xff056103 when i tried
Post by Billycar11 » Tue Nov 03, 2026 10:04 pm
JediFonger wrote: Tue Nov 03, 2026 9:35 pm command produced error code 0xff056103 when i tried
See guide below and make sure no disc in in the drive
JediFonger
Post by JediFonger » Wed Nov 04, 2026 12:16 am
Billycar11 wrote: Tue Nov 03, 2026 10:04 pm
reflashed, thx! why not 1.03?
JediFonger
Post by JediFonger » Wed Nov 04, 2026 12:18 am
reflashed to lg. behavior unchanged. i’ll try poweroff
JediFonger
Post by JediFonger » Wed Nov 04, 2026 12:32 am
poweroff and on same thing:
DEBUG: Code 3221225506 at VJs9j8g7;i#^WIj*:121267293
Post by Coopervid » Wed Nov 04, 2026 11:45 am
JediFonger wrote: Wed Nov 04, 2026 12:32 am poweroff and on same thing:
Post your Makemkv info.
JediFonger
Post by JediFonger » Wed Nov 04, 2026 12:38 pm
there is none. if u cant read the disc there are no logs for that i have debug enabled i’m gettin nothing
Post by Coopervid » Wed Nov 04, 2026 12:48 pm
JediFonger wrote: Wed Nov 04, 2026 12:38 pm there is none. if u cant read the disc there are no logs for that i have debug enabled i’m gettin nothing
I would like to see the Makemkv info w/o a disc in the drive. Just to be sure that your drive has been successfully flashed to the LG firmware.
JediFonger
Post by JediFonger » Wed Nov 04, 2026 1:21 pm
Coopervid wrote: Wed Nov 04, 2026 12:48 pm
Debug log started at Wed Nov 04 13:20:23 2026 , written by MakeMKV v1.18.4 win(x64-release)
001005:0000 MakeMKV v1.18.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Administrator/MakeMKV_log.txt
DEBUG: Code 3 at @"msWTt'T11F$o0`O'm,^T]+:29395310
SDF v0a6: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLLL3TG0419
No SDF v0a6: Lenovo_Slim_USB_Burner_LA01_201411181942_KO9ZB5G4554
SDF id v0a6: Lenovo_Slim_USB_Burner_LA01_201411181942_KO9ZB5G4554
No SDF v0a6: HL-DT-ST_BD-RE_BT30N_GL02_20121113123456_M6A23C33226
DEBUG: Code 0 at ^vtIK838cpxb-"!F7:29396253
DEBUG: Code 0 at VJs9j8g7;i#^WIj*:213136746
001012:0000 udf: node fe/efe failed!
SDF id v0a6: HL-DT-ST_BD-RE_BT30N_GL02_20121113123456_M6A23C33226
Application exited at Wed Nov 04 13:20:39 2026
Post by Coopervid » Wed Nov 04, 2026 1:30 pm
Now clean the 4k discs with liquid soap and warm water. Dry with a paper towel and wipe with a microfiber cloth. Then try again reading with the LG firmware you have flashed. These discs have very often an invisible film even new and spotless.
