'This disc uses newer version of AACS protection' - What am I misssing that I still can't rip to MKV from this blu-ray d
swan36fc
Post by swan36fc »
Greetings!
I have followed all relevant recommendations on this forum to resolve this common issue but I am still stuck. Can you help?
(In my case the problem disc is the blu-ray disc included with the deluxe version of Rick Wakeman's Return to the Red Planet, released Oct 2nd.)
First, I followed this instructions to install the Libre Drive firmware onto my copy if MakeMKV, and I was successful.
The posts I read here stated that if I have the Libre drive installed I wouldn't need to worry about having the latest db keys to rip the disc.
This has not prooven to be the case.
1) Is this correct or not?
Second, assuming having Libre drive installed won't allow me to rip this new blu-ray disc, I have followed the given instructions on this forum to get the keys for this disc added to the database MKV uses. So, I e-mailed the tgz dump file to svq@makemkv.com back on October 22nd. I have been downloading the latest keydb file from https://fvonline-db.bplaced.net/ over the last several days and placing the latest keybd.cfg file into my .MakeMKV folder on my Windows PC and running MakeMKV attempting to rip the new disc with no success.
So, here are my questions:
1) Am I getting some of this wrong?
2) Am I being impatient? Am I expecting the database to be updated with keys for this disc too soon?
3) Or should the LibreDrive be working without the need for keys, etc,?
Thanks in advance for your help!!
OK, here is all the info pasted from the software:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: M63IA592625
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: RETURN_TO_THE_RED_PLANET
Timestamp: 2026-07-20 10:46:44
Protection: AACS v82
Data capacity: 15.26 Gb
Disc type: BD-ROM
Number of layers: 1
MakeMKV v1.17.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?iotLngRXbBoOze...
Saved AACS dump file as C:\Users\Alex/.MakeMKV/MKB_v82_Rick_Wakeman_-_Return_to_the_Red_Planet_1270.tgz
Re: 'This disc uses newer version of AACS protection' - What am I misssing that I still can't rip to MKV from this blu-r
swan36fc wrote: Mon Nov 02, 2026 9:25 pm Greetings!
Revision: 1.02
Disc Information
Disc type: BD-ROM
Number of layers: 1
The problem is that you are using an old version of MakeMKV that does not natively decrypt AACS v82 discs. Update to MakeMKV v1.18.4 and you will be able to rip it. Do not use MakeMKV v2.0.0 as it has various issues.
swan36fc
Post by swan36fc »
Thank you!
In my case I have my software and files on a non-Internet PC. I did just download this file from MKV:
makemkv_v1.18.4_osx.dmg 2026-06-15 17:38 42M
Will I be able to place this file in one of the folders of my current version to where it can update to this version?
swan36fc wrote: Tue Nov 03, 2026 12:05 am Thank you!
I'm a Windows user. I have no idea how you install software on a Mac. It's foreign to me..
16442496
Post by 16442496 »
MakeMKV 2.0.0 for Windows
https://makemkv.com/download/Setup_MakeMKV_v2.0.0.exe
16442496
Post by 16442496 »
16442496 wrote: Tue Nov 03, 2026 5:14 am
and old versions: (.exe for Windows)
https://makemkv.com/download/old/
16442496 wrote: Tue Nov 03, 2026 5:17 am
Do not use v2.0.0! It has issues.
Why are you posting these links? He is not using Windows.
swan36fc
Post by swan36fc »
Hi all, I appreciate your input on this!!
Actually, my non-Internet PC is running Windows, I just posted the wrong file. Thanks for catching that!!
I now have the correct file: v1.18.4 for Windows setup.
This does raise some questions, so here goes:
1) If I install this new version, will I lose my existing firmware setup for LibreDrive?
2) Is there another way I can update to v1.18.4 without a full install?
Thanks!!
"full install" just means you told the installer to put everything in... but it doesn't mean you OVERWROTE the original install. Just use a different directory.
I personally have almost a dozen different installs on my system. Some work better with certain disks than others.
16442496
Post by 16442496 »
MartyMcNuts wrote: Tue Nov 03, 2026 6:02 am
Maybe because first post says:
"MakeMKV v1.17.1 win(x64-release) started"
swan36fc
Post by swan36fc »
Many thanks to everyone!
The v1.18.4 is running nicely and running as I write this.
gwhitcombe71
Post by gwhitcombe71 »
MartyMcNuts wrote:The problem is that you are using an old version of MakeMKV that does not natively decrypt AACS v82 discs.
MartyMcNuts, agreed on skipping v2.0.0, I stuck with 1.18.4 too and its been proper good.
