MAC ver 2.0 will not install
cazzie98
Post by cazzie98 » Sun Nov 01, 2026 3:00 pm
I’m running macOS Golden Gate 27.2 and am trying to install MakeMKV 2.0, but I can’t get the installation to complete.
I’ve bypassed Gatekeeper using the “Open Anyway” option, but the application still won’t install. I’ve tried twice, completely removed the app, and restarted my Mac, but I’m still having the same issue.
Has anyone else experienced this problem or found a solution? Any help or suggestions would be greatly appreciated!
How can I fix this, HELP !
Re: MAC ver 2.0 will not install
Post by Woodstock » Sun Nov 01, 2026 6:51 pm
in reading the forum, you are better off installing one of the 1.18 versions for now - 2.0.0 has problems with a lot of disks.
cazzie98
Post by cazzie98 » Mon Nov 02, 2026 1:13 pm
Woodstock wrote: Sun Nov 01, 2026 6:51 pm in reading the forum, you are better off installing one of the 1.18 versions for now - 2.0.0 has problems with a lot of disks.
Where can I find the older versions to download?
Post by Woodstock » Mon Nov 02, 2026 4:59 pm
