Public KeyDB Disc Submissions
fujiland2046
Post by fujiland2046 »
fujiland2046 wrote: Thu Oct 29, 2026 10:11 am Disc type: UHD - The Protector, label 88FU046B
Disc ID: C8C751E0793B4E9340B2AEF6E247FA37BE385EBE
Disc dump filename: MKB20_v82_88FU046B_FC73.tgz
Drive: Asus BC-12D2HT (Corrected)
Drive firmware: 3.00 (Corrected)
Hey fujiland2046, thanks for following the submission template but your disc drive firmware doesn't allow creating complete disc dump files. If the MakeMKV status for your drive contains this line:
BD raw metadata read: Partial
It means that you'll need to flash an alternative firmware. I think your drive should be compatible with the WH16NS60 firmware series but I'd double check in the LibreDrive section of the forum. Once your drive has been flashed and you see:
Feel free to generate a new disc dump file and post it to this thread.
Hi, here is the new disc dump by LG LibreDrive
Drive: LG BU40N
Drive firmware: 1.00 https://drive.google.com/file/d/1lR7_tA ... drive_link
and also the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1INFA-v ... sp=sharing
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v72_Jaws_CC5B
*MKB20_v82_88FU046B_FC73
*MKB20_v82_FRANKENSTEIN_-_DISC_ONE_C7CA
*MKB20_v82_FRANKENSTEIN_-_DISC_TWO_B976
*MKB20_v82_Gone_with_the_Wind_Part_1_F7B2
*MKB20_v82_Gone_with_the_Wind_Part_2_76E8
*MKB20_v82_The_Family_Man_8442
*MKB20_v82_The_Uprising_7B98
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
AverZippy
Post by AverZippy »
Disc type: UHD (ARCANE S1 DISC 2 UHD)
Disc ID: 4f9dd2df02a6c54793732e7fcd0675cb9a49a468
Disc dump filename: MKB20_v77_ARCANE_SEASON_1_-_DISC_2_189F.tgz
Drive: HL-DT-ST BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Is your MKB_RO.inf file size at least 2MB? yes
MKB_RO.inf link: (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc) https://drive.google.com/file/d/1mh6wiU ... drive_link
Disc dump link: https://drive.google.com/file/d/10GEIed ... drive_link
keydb_helper
AverZippy wrote: Fri Oct 30, 2026 1:34 am Disc type: UHD (ARCANE S1 DISC 2 UHD)
Thanks for the submission AverZippy. Your disc has been added to the public keydb.
KeyDB Priority List
aikonzx
Post by aikonzx »
KOUYASAN 4K UHD
Disc type: UHD
Disc ID: 9543BF7C277FB5684949F21509D42627EAA224F8
Disc dump filename: MKB20_v76_KOUYASAN_428A
Drive: LG BD-RE BU40N
Drive firmware: 1.03
Is your MKB_RO.inf file size at least 2MB? Yes
MKB_RO.inf link: https://drive.google.com/file/d/1fZ-zsX ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1q3LbBW ... sp=sharing
bdsucker
Post by bdsucker »
Disc type: UHD
Disc ID: 0x5FD641D5CBFFCBB7A4EBD51B0A840629C9BF657B
Disc dump filename: MKB20_v82_SALO_7CFA
Drive: BW-16D1HT
Disc dump link: https://www.mediafire.com/file/yg8sr98c ... A.tgz/file
keydb_helper
bdsucker wrote: Fri Oct 30, 2026 9:38 am Disc type: UHD
Thanks for the submission bdsucker. Your disc has been added to the public keydb.
KeyDB Priority List
keydb_helper
I've added a link to my forum signature (KeyDB Priority Titles). It contains a list of disc ID and disc title pairs. These correspond to UHD discs with known unit keys but no known media keys. Discs are grouped together according to shared unit keys and these groups are then sorted according to group size.
As an example, the first group (LUCYUHD_NA) corresponds to six distinct discs which all share the same unit key and none of them have complete keydb records. If a disc dump file for any disc from this group can be provided, the other 5 discs can have complete records generated by users on a self-serve basis.
If anyone has any disc from this list of titles, it would be greatly appreciated if you could follow these steps and provide the resultant 'synthetic' disc dump file:
1. Use MakeMKV to start creating an encrypted folder backup of a disc
2. Stop the backup once the discatt.dat/discattd.dat file has been created and at least one M2TS file has been copied
(A very small M2TS file is sufficient for this purpose)
3. Make a new folder for your synthetic disc dump
4. Copy the discatt.dat/discattd.dat file and the smallest M2TS file out of the (incomplete) encrypted backup folder into your synthetic disc dump folder
5. Copy the entire AACS directory from your disc into your synthetic disc dump folder
6. Zip up the synthetic disc dump folder, upload it to a file host and post a link here
If MakeMKV happens to organically create a disc dump file, please feel free to follow the standard submission procedure by including the full MKB_RO.inf file alongside the disc dump file.
Edit History:
  • 2026-11-01: Updated Pastebin link, Removed Guardians of the Galaxy: Vol. 2 thanks to dagwed
  • 2026-11-02: Updated Pastebin link, Removed Lucy thanks to turbov6camaro
Last edited by keydb_helper on Mon Nov 02, 2026 11:41 am, edited 2 times in total.
KeyDB Priority List
Post by SamuriHL »
Arguably that's a better method for creating dump files anyway for all discs as it ensures the right files are always present.
badboy
Post by badboy »
Disc type: UHD
Disc ID: FB8A0CE1690C57A5F651104EAC7F26A8264F5ECB
Disc dump filename: MKB20_v82_VIVRE_UHD_BEF4
Drive: BW-16D1H-U
Drive firmware: A204
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link: https://drive.google.com/file/d/1pM9opw ... sp=sharing
Disc dump link:https://drive.google.com/file/d/13kcSWY ... sp=sharing
ng1988
Post by ng1988 »
The UHD file cannot be opened at the moment, as it was only recently released. Here is a link for it.
https://drive.google.com/file/d/1JoXg3D ... sp=sharing
turbov6camaro
Post by turbov6camaro »
Six more 4K discs from today. All dumps were packed with the full MKB_RO.inf inside the .tgz, and the same MKB_RO.inf was copied straight from each disc.
None of these disc IDs has a volume key in the keydb yet. Spider-Man 3 (2007) has a partial record (disc ID + unit key only, no V), so MakeMKV still reports "The volume key is unknown for this disc". The other five have no record under these disc IDs.
Disc type: UHD (4K Ultra HD Blu-ray) - Spider-Man (2002), label SPIDERMAN_2002
Disc ID: B43813F835C9A219468A916D274FCE9B7A442990
Disc dump filename: MKB20_v61_Spider-Man_(2002)_AB99.tgz
Drive: LG BP60NB10
Is your MKB_RO.inf file size at least 2MB? Yes (5 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1zd5KB- ... YaJqT/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1zd5KB- ... YaJqT/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Spider-Man 2 (2004), label SPIDER_MAN_2_2004
Disc ID: FCAD84D6362BB7452BE98730DE16FE9F4141CAA9
Disc dump filename: MKB20_v61_Spider-Man_2_(2004)_C9FD.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1J6smQr ... xwvZa/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1J6smQr ... xwvZa/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Spider-Man 3 (2007), label SPIDER_MAN_3_2007
Disc ID: 9BDF6EFF7AF3303786B78D64A5E4F40FF68D928B
Disc dump filename: MKB20_v61_Spider-Man_3_(2007)_8347.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1gcM1CF ... 6uNds/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1gcM1CF ... 6uNds/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - The Amazing Spider-Man, label AMAZING_SPIDER-MAN_THE
Disc ID: A0B0C6A332F3DDC03CE5EBE00F56643D974372E4
Disc dump filename: MKB20_v60_Amazing_Spider-Man_ECFB.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1BhMjzO ... APSoW/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1BhMjzO ... APSoW/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Spider-Man: Homecoming, label SPIDER_MAN_HOMECOMING
Disc ID: 47C6242A085408ECBF22F28E3A1828C18407A902
Disc dump filename: MKB20_v61_Spider-Man-_Homecoming_8959.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1JHdG1y ... KhUZz/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1JHdG1y ... KhUZz/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Alita: Battle Angel, label ALITA_BATTLE_ANGEL
Disc ID: 01CE218293FB243F1EFA7C740C585E1E71A0DB82
Disc dump filename: MKB20_v72_Alita-_Battle_Angel_FA71.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1shJlmn ... lnAgw/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1shJlmn ... lnAgw/view (same zip)
psm2k
MKB20_v77_The_Exorcist-_Extended_Director's_Cut
Post by psm2k »
Disc type: UHD Blu-ray (AACS 2.0, MKB v77)
Disc ID: 48958AFB1D33D9B5108465DA6CF473E2AFC9AE63
Disc dump filename: MKB20_v77_The_Exorcist-_Extended_Director's_Cut_AF8B.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://app.filen.io/#/d/97b5a54c-2408- ... HfDaWlkdVm
Disc dump link: https://app.filen.io/#/d/e8244dd6-8c26- ... BwssaZgMNy
Thank you for Jaws!!
psm2k
Post by psm2k »
Exorcist Theatrical Release UHD 4k
Disc ID: 4027C9FFDE410373F11546828DD91E54408B28E0
Disc dump filename: MKB20_v77_The_Exorcist_9921.tgz
MKB_RO.inf link: https://app.filen.io/#/d/a2149450-2870- ... myfGsRZhv1
Disc dump link: https://app.filen.io/#/d/ab5ce1cd-6dad- ... Q984tD5vgB
turbov6camaro
One more from today. The dump was packed with the full MKB_RO.inf inside the .tgz, and the same MKB_RO.inf was copied straight from the disc.
This disc ID has only a partial record in the keydb (disc ID + unit key, no V), so MakeMKV still reports "The volume key is unknown for this disc". This is the UK/Ireland 2-movie collection pressing.
Disc type: UHD (4K Ultra HD Blu-ray) - Ant-Man and the Wasp, label ANT_MAN_AND_THE_WASP
Disc ID: 2E5426395311BAB3FEAA663582964505BB269F71
Disc dump filename: MKB20_v65_MARVEL'S_ANT-MAN_AND_THE_WASP_-_ULTRA_HD_EBF3.tgz
Drive: LG BP60NB10
Is your MKB_RO.inf file size at least 2MB? Yes (128 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/18w1Dp6 ... nehy-/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/18w1Dp6 ... nehy-/view (same zip)
