hello new to this so thanks in advance for your patience.
checking to see if there is a specific firmware for this drive
Manufacturer: ASUS
Product: BC-12B1ST b
Revision: 3.11
Serial number: SIK91GASB273
Firmware date: 2119-02-27 13:21
Bus encryption flags: 1E
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 3.11
thanks for your help
ASUS BC-12B1ST b Status: Possible (with patched firmware)
12gametal
zittrig
Re: ASUS BC-12B1ST b Status: Possible (with patched firmware)
Flash to LG WH16NS60 1.02 MK.
12gametal
zittrig
It should. Just try.
tomty89
While WH16NS60 1.02MK (and BW-16D1HT 3.10MK) would probably work fine as well, there is MK version of BC-12B1ST b 3.11 in the "official" MK firmware pack.12gametal wrote: Thu Oct 22, 2026 9:23 pm checking to see if there is a specific firmware for this drive
Apparently WH16NS60 1.02MK has no "sleep bug". (I don't remember if it has "jamless playback" -- which is "bad" -- like the BU40N firmware though.)
Barley
I didn't know the Asus BC-12B1ST b could be flashed to other player firmwares. I had flashed it to the MK version of BC-12B1ST b 3.11 from the "official" MK firmware pack. It read 4k UHD discs, but was very unreliable, failing to rip several discs that my Pioneer breezed through. Would the drive be more reliable with WH16NS60 1.02MK or BW-16D1HT 3.10MK?
gwhitcombe71
Barley, when you say it failed on several discs, was it throwing read errors partway through or just refusing to start? (also did you try the same discs on a different SATA cable or port... i've had a dodgy cable cause proper weird stuff before). Which Pioneer have you got, out of interest?
Barley
Some discs would rip successfully on the first try. Others, I would get errors mid-rip. Washing the discs (sometimes multiple times) sometimes worked. Other discs never completed successfully. Swapped it for a Pioneer BDR-209 flashed to BDR-S11J-X, and every disc ripped successfully every time (same SATA cable and port).gwhitcombe71 wrote: Thu Oct 29, 2026 9:17 pm Barley, when you say it failed on several discs, was it throwing read errors partway through or just refusing to start? (also did you try the same discs on a different SATA cable or port... i've had a dodgy cable cause proper weird stuff before). Which Pioneer have you got, out of interest?
tomty89
I'd say it's at best 50/50. AFAIK BC-12B1ST b is quite an old model, meaning that the drive is probably quite old, if not worn. While in certain cases changing firmware (more specifically downgrading to an older firmware, I think, like in the case of BU40N) allegedly helps in making a drive works better for certain disc / in certain OS, it's not very likely going to help in this case. Also Pioneer drives are known to work better in most cases anyway.Barley wrote: Wed Oct 28, 2026 12:09 pm I didn't know the Asus BC-12B1ST b could be flashed to other player firmwares. I had flashed it to the MK version of BC-12B1ST b 3.11 from the "official" MK firmware pack. It read 4k UHD discs, but was very unreliable, failing to rip several discs that my Pioneer breezed through. Would the drive be more reliable with WH16NS60 1.02MK or BW-16D1HT 3.10MK?
12gametal
First thanks to everyone for the information.tomty89 wrote: Fri Oct 30, 2026 5:23 amI'd say it's at best 50/50. AFAIK BC-12B1ST b is quite an old model, meaning that the drive is probably quite old, if not worn. While in certain cases changing firmware (more specifically downgrading to an older firmware, I think, like in the case of BU40N) allegedly helps in making a drive works better for certain disc / in certain OS, it's not very likely going to help in this case. Also Pioneer drives are known to work better in most cases anyway.Barley wrote: Wed Oct 28, 2026 12:09 pm I didn't know the Asus BC-12B1ST b could be flashed to other player firmwares. I had flashed it to the MK version of BC-12B1ST b 3.11 from the "official" MK firmware pack. It read 4k UHD discs, but was very unreliable, failing to rip several discs that my Pioneer breezed through. Would the drive be more reliable with WH16NS60 1.02MK or BW-16D1HT 3.10MK?
Now it looks like it's time for an upgrade.
Not trying to open a can of worms but what would be you're recommendation for a new drive?
Pioneer, LG then modle of said drive.
gwhitcombe71
fair enough mate, same cable and port rules that out then... sounds like the drive itself is just knackered or a bit fussy with the laser (they do wear, to be fair). the BDR-209 is a proper good shout, ive heard alot of folk say they just get on with it. i reckon id stick with the Pioneer and keep the Asus as a spare for the odd discBarley wrote:Some discs would rip successfully on the first try. Others, I would get errors mid-rip.
Barley
Upgrading is not as simple as it was a year or two ago. Now that the major manufacturers are no longer manufacturing these drives, you must pay exorbitant prices for New Old Stock or Used. I would try flashing your unit and see how it works for you.12gametal wrote: Sat Oct 31, 2026 12:26 pm First thanks to everyone for the information.
12gametal
Thanks for all of your input. I will try flashing my drive.
and post what happens.
Barley
Which firmware are you going to use?12gametal wrote: Sun Nov 01, 2026 1:30 pm Thanks for all of your input. I will try flashing my drive.
Barley
@12gametal, have you flashed your drive yet? Waiting for your results before I try the same!12gametal wrote: Sun Nov 01, 2026 1:30 pm Thanks for all of your input. I will try flashing my drive.
