Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
rudolf_slch
Re: THIS!
Post by rudolf_slch »
jwagner wrote: Sun Oct 11, 2026 9:21 pm Hey everyone I wanted to post this on the forum to let everyone know that there is an affordable slim 4K Blu-ray optical drive that has a factory firmware that works out of the box with MakeMKV. I tested it with 4K, Blu-Ray and standard DVDs last night and it works successfully without any firmware modification.
thank you very much for this information. I ordered the device, it arrived today and indeed
it is working perfectly! I should have read your post before because some days before I
bought a VERBATIM 43888 without thinking! Only then when I realized that it will only work
after flashing I started reading this forum. Anyway I have I nice drive now. I let makemkv 'prepare'
the drive and with a simple 'dd' I can generate an image from the disc as I always do with
discs! Thank you!
Stefan2k22
Re: Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Post by Stefan2k22 »
Billycar11 wrote: Sun Oct 11, 2026 3:27 am
Mr_Orange wrote: Sun Oct 11, 2026 2:34 am For the Asus SBW-06D2X-U, it states only the 8510/8511 platform is compatible with flashing. Are there versions of this unit around with a different platform? Would it be safe to buy one now?
there are 4 versions at least really one has lg
so could be more
known ones are BU40N ,UD03 8510, UD03 8511, UD03 8590 there could be more
Got one of these drives. Mine reports this in MakeMKV
Product: BD-RE BU40N
Revision: FR07
Serial number: XXXXXXXXXXX
Firmware date: 2119-05-10 13:48
Bus encryption flags: 1F
Highest AACS version: 64
Any tips on how to enable Libredrive on this one or what firmware I might need?
Mr_Orange
Post by Mr_Orange »
Stefan2k22 wrote: Sun Oct 25, 2026 1:17 am
so could be more
Revision: FR07
Follow the instructions on page 1 of this thread to flash a BU40N to 1.03MK.
Revision: FR07
Sure see guide below or email me or Marty for an automated flasher
stingray21
Re: THIS!
Post by stingray21 »
https://www.amazon.com/dp/B0H1HNDPCL?re ... asin_title
IF the link doesn't work you can search for the title "JOTEC Premium Aluminum 4K UHD External Blu-Ray Drive
4K Blu-ray Burner, USB 3.0 & Type C Dual Interface, Compatible with All PC & Mac Models, Support 100GB 128GB"
The manufacturer ships both BU40N BU50N models. It retails for $142.99
In my case it handshakes with the MakeMKV status message of-
OS device name: /dev/rdisk4
Current profile: DVD-ROM
Revision: FR07
Firmware date: 2116-12-20 16:51
Highest AACS version: 82
Firmware version: 0.FR07J
I used the forum to flash a Verbatium BU40N (much more expensive but I was able to get it flashed thanks to everyone and Mike). I decided to buy a cheaper drive as a back up to flash while the process was in my memory. And much to my surprise the JOTEC has a better build quality and works out of the box with old school factory firmware.
I ordered this drive from amazon because of the post above and it says in the amazon reviews that it works out of the box (without flashing). However it does not read any 4K Bluray for me, nor does it show any LibreDrive information in makemkv:
OS device name: F:
Revision: CB05
Serial number: XXXXXXXXXXXXX
Firmware date: 2117-11-29 13:51
Highest AACS version: 57
The SDFtool Flasher also shows "MT1959 Platform: X"
Does this mean the drive cannot be flashed?
Mr_Orange
Re: THIS!
Post by Mr_Orange »
stingray21 wrote: Wed Oct 28, 2026 12:59 am
Revision: FR07
OS device name: F:
Revision: CB05
You should post the full info screen that MakeMKV provides for your drive for confirmation.
On the basis that it is a BU40N with an MT1959 drive platform, follow the instructions on page 1 of this thread to flash a BU40N to 1.03MK.
stingray21
Thank you for the reply
This is the full info screen (besides the X-out serial number and "No disc inserted")
The "MT1959 Platform: X" (the "X" is red) makes me think it's not MT1959 platform
Mr_Orange
Post by Mr_Orange »
stingray21 wrote: Wed Oct 28, 2026 9:15 pm Thank you for the reply
We need to see the Libredrive information from MakeMKV.
stingray21
I apologize if I didn't communicate it clearly, that is what confuses me, it does not show any LibreDrive info.
I tried it on Windows (v2.0.0 and v1.18.4) and Linux; with no disc, with a bluray, a 4K bluray.
I attached a screenshot to the last past, but it didn't go through.
stingray21 wrote: Thu Oct 29, 2026 4:45 pm I apologize if I didn't communicate it clearly, that is what confuses me, it does not show any LibreDrive info.
Use a service like imgur or similar attachments don't work here
stingray21
Billycar11 wrote: Thu Oct 29, 2026 9:28 pm
https://imgur.com/a/Kmj1OGE
stingray21 wrote: Thu Oct 29, 2026 11:01 pm
get a recommended usb case from the guide its blocking flashing and full drive info
kuro2K20
Post by kuro2K20 »
I have a Pioneer S12UHT (Firmware 1.01) and I’m wondering : is it worth performing a crossflash to the S12XJ ?
If so, what benefits would it provide ?
And could someone help me with using the right software and the correct firmware(s) ?
kuro2K20 wrote: Sat Oct 31, 2026 2:16 am Hi,
No benefit. Leave it alone.
kuro2K20
Post by kuro2K20 »
MartyMcNuts wrote: Sat Oct 31, 2026 2:19 am
Ok, thank you ! ^^
