Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
DaywalkerNL
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Post by DaywalkerNL » Mon Sep 21, 2026 2:28 pm
Hello, i just found it with google =)
i want to ask ,can my device read 4k blu rays ? many thanks for the Information
Laufwerksinformation
OS-Gerätename: G:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer: OJDL020125WL
Firmware-Datum: 2016-04-25
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.34/ID43
Post by Coopervid » Mon Sep 21, 2026 3:36 pm
DaywalkerNL wrote: Mon Sep 21, 2026 2:28 pm Hello, i just found it with google =)
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.34
PM sent.
Post by Billycar11 » Mon Sep 21, 2026 9:37 pm
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.34
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
elfaham
Post by elfaham » Sun Sep 27, 2026 3:14 am
It's my 1st post too. And I got the same drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.10
Serial number: XXXXXX
Firmware date: 2013-10-15
Firmware version: 1.10/ID43
Post by Billycar11 » Sun Sep 27, 2026 9:26 pm
elfaham wrote: Sun Sep 27, 2026 3:14 am Hello,
OS device name: F:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Post by Coopervid » Mon Sep 28, 2026 10:13 am
OS device name: F:
Revision: 1.10
PM sent.
bumsvallera
UHD Blu-ray reading my Pioneer BDR-S09
Post by bumsvallera » Thu Oct 22, 2026 5:35 pm
I would like to enable UHD Blu-ray reading on my Pioneer BDR-S09 if possible.
My drive information:
OS device name: /dev/sr0
Revision: 1.34
Firmware date: 2016-04-25
Could you please advise whether this drive is compatible and provide the appropriate firmware and flashing instructions?
Thank you!
Re: UHD Blu-ray reading my Pioneer BDR-S09
Post by Coopervid » Fri Oct 23, 2026 9:40 am
bumsvallera wrote: Thu Oct 22, 2026 5:35 pm Hello,
Revision: 1.34
Thank you!
Please tell me which OS you use and which hardware (ARM or Intel). Then I will send the right package.
Post by Billycar11 » Fri Oct 23, 2026 9:47 am
Revision: 1.34
Thank you!
Sure just email me
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
Joris222
Post by Joris222 » Thu Oct 29, 2026 3:25 pm
Could someone help me enable UHD reading on my Pioneer BDR-S09XLT?
My drive information from MakeMKV is:
Model: Pioneer BDR-S09XLT
Revision: 1.34
It reads ordinary Blu-rays but does not recognise UHD discs. Is a suitable firmware modification available for this drive, and how can I obtain the correct flasher?
Thank you,
Joris222
Post by Billycar11 » Thu Oct 29, 2026 9:28 pm
Joris222 wrote: Thu Oct 29, 2026 3:25 pm Hello,
Revision: 1.34
Thank you,
Joris222
Sure just email me
trevbot
Post by trevbot » Fri Oct 30, 2026 9:09 pm
Hi Joris, I make trev.bot. It can flash the S09 for UHD too, with a GUI on Windows, Mac and Linux. You can check your drive for free before buying a license: https://trev.bot/pioneer/bdr-s09
