Spider-Man - No way home UHD - can't be read
remuxer_ger
Post by remuxer_ger » Wed Oct 28, 2026 8:02 pm
Hi again,
this one also will not read in my
Pioneer BDR-UD04 (Blu-ray-Writer).
- Firmware: 1.14
- Plattform: RS8A10
- Anschluss: USB (extern)
same error: "AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
The AACS dump file "E:/temp mkv/MKB20_v76_Spider-Man-_No_Way_Home_BA7D.tgz" was successfully sent for analysis
Das Öffnen der Disk schlug fehl
Thx for help
remuxer
Re: Spider-Man - No way home UHD - can't be read
Post by MartyMcNuts » Wed Oct 28, 2026 11:00 pm
remuxer_ger wrote: Wed Oct 28, 2026 8:02 pm Hi again,
- Firmware: 1.14
- Plattform: RS8A10
Thx for help
remuxer
I see you have a Pioneer BDR-UD04 but what do you actually have? Is it a Verbatim 43888? They are known to be a bit power hungry so it might be a power issue. Ensure you are using a USB (USB-C if possible) port direct from the motherboard (not case ports) or an AC self-powered USB hub of at least 24w. The latter is often true for laptops since they often don't provide enough constant power for an optical drive.
Can you copy and paste the full Drive Info and Libredrive Info sections from MakeMKV.
remuxer_ger
Post by remuxer_ger » Thu Oct 29, 2026 10:13 am
Yes, it's a Verbatim 43888.
It comes with a USB C 3.2 (in the Drive) to USB A 3.2 Cabel.
I will change the original Cabel to a USB C 3.2 to USB C 3.2 Cabel and connect it to the USB C Case Port - unfortunately, this did not bring any success either.
Next I connected the cable directly to the motherboard rear. USB-C should actually deliver 5 V / 3 A.
But according to the specifications of my motherboard (MSI MPG Z790 Carbon WiFi), the USB-A and USB C 3.2 port only delivers 5 V / 0.9 A via the motherboard cable to the front case port and to the rear ports of the Mainboard.
Unfortunately, the manual does not document the maximum current or USB PD performance for the internal connection. So it can only be assumed that on the rear side of the Mainboard the USB A and C port delivers only 5 V / 0,9 A. At least I bypass the additional cabling with the thin/poor quality wiring to the USB front case.
Post by MartyMcNuts » Thu Oct 29, 2026 10:24 am
remuxer_ger wrote: Thu Oct 29, 2026 10:13 am Yes, it's a Verbatim 43888.
I will change the original Cabel to a USB C 3.2 to USB C 3.2 Cabel and connect it to the USB C Case Port.
If that doesn't work, I connect the cable directly to the motherboard. USB-C should actually deliver 5 V / 3 A.
But according to the specifications of my motherboard, the USB-A 3.2 port only delivers 5 V / 0.9 A via the motherboard cable to the case port.
To the USB C port of the case but 5 V / and up to 3 A. That could be the cause.
Do not use case ports!! Most of the time, case manufacturers use thin/poor quality wiring for the USB ports that is not good enough to provide sufficient constant power for an optical drive. Case ports are fine for thumb drives etc but not for optical drives. Use either a port direct from the motherboard or an AC self-powered USB hub of at least 24w. Also, the Verbatim enclosures are known to be quite power hungry.
remuxer_ger
Post by remuxer_ger » Thu Oct 29, 2026 1:41 pm
👍 seems to work now as it should - connected via the original cable at the backside red USB A Port.
Is associated with a little bending :lol: , but the main thing is that it works
THX !
gwhitcombe71
Post by gwhitcombe71 » Thu Oct 29, 2026 11:10 pm
remuxer_ger, which rear port did you end up using, a USB 3.2 one or one of the older 2.0 ones? Also, did the drive read it first go or did it take a few goes to spin up (just curious, my old external did that)...
Post by MartyMcNuts » Fri Oct 30, 2026 12:39 am
gwhitcombe71 wrote: Thu Oct 29, 2026 11:10 pm remuxer_ger, which rear port did you end up using, a USB 3.2 one or one of the older 2.0 ones? Also, did the drive read it first go or did it take a few goes to spin up (just curious, my old external did that)...
The RED USB-A port is generally 3.2
remuxer_ger
Post by remuxer_ger » Fri Oct 30, 2026 11:05 am
All of the rear USB A Ports are 3.2 but with different speeds (see my picture).
MSI documents that the rear USB ports are partly connected directly and partly additionally via an internal USB hub. Unfortunately, which one exactly is not mentioned. Therefore, I checked the assignment by replugging my Verbatim drive with USBTreeView and was able to determine the following.
In order to get as constant a power supply as possible, an optical drive is best connected to a connector that is connected directly to the motherboard without a hub.
My drive is now connected to one of the green marked direct connectors and runs without errors. See my picture.
Post by dcoke22 » Fri Oct 30, 2026 2:49 pm
remuxer_ger wrote: Fri Oct 30, 2026 11:05 am My drive is now connected to one of the marked direct connectors and runs without errors. See my picture.
Hmmm... the Photo will not show up?
Your best bet is to post the picture somewhere on the internet (https://imgur.com for instance) and then post a link here.
