makemkv no longer reads Blu-ray ISO files
charlie14
Post by charlie14 »
Recently, MakeMKV has stopped reading Blu-ray ISOs. After selecting the ISO, the program freezes. I've tried it on three different computers and with various ISOs. No luck. Even after reinstalling it on a fresh Windows 11 system, nothing has changed. What could be causing this?
Re: makemkv no longer reads Blu-ray ISO files
Which version of MakeMKV?
There have been reports of the latest 2.0 version having issues with ISOs, but older versions work fine.
charlie14
Post by charlie14 »
2.0.0
I’ve reinstalled it on three different computers. No chance – it just freezes.
Then I'd recommend picking up one of the 1.18.x versions, if you don't already have it. They're all at https://www.makemkv.com/download/old/ to pull the one you want/need.
You can have multiple versions installed. I have about 8 here, along with the install files for others. You can even run multiple versions at one time, as long as they're controlling different drives.
charlie14
Post by charlie14 »
Hello, and thank you for the tip.
I’ve reverted to version 1.18.4.
It’s now working as it did before.
AlexKid
Post by AlexKid »
thank you
I had the same error, while loading an ISO makemkv freezes and returns an "ERROR"
with v1.18.4 all is fine
gwhitcombe71
Post by gwhitcombe71 »
AlexKid wrote:thank you I had the same error, while loading an ISO makemkv freezes and returns an "ERROR" with v1.18.4 all is fine
AlexKid, mine was a bit different... no "ERROR" box at all, it just sat there with the window greyed out till i killed it in task manager. I didnt bother with 1.18.4 either, just dug out 1.18.2 from an old laptop (still had the installer sat in a folder) and that read the same ISOs fine. Funny thing is, mounting the ISO as a virtual drive and opening that in 2.0.0 worked for me, but it was proper slow so i gave up on it. Ive left 2.0.0 installed alongside, to be fair, just so i can try it again when they patch it.
GravuTrad
Post by GravuTrad »
2.0.0 is buggy. i hope a correct release soon
