Flash Problematic LibreDrive Enabled WH14NS40 to WH16NS60?
khargy
Post by khargy »
So I have a WH14NS40:
OS device name: /dev/sr0
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: XXXXXXXX
Highest AACS version: 82
Firmware version: 1.05
Sometimes it has trouble reading certain UHD disc... the problematic discs work fine in my other drives.
Is it worth flashing to WH16NS60-1.02 to see if it helps any?
Re: Flash Problematic LibreDrive Enabled WH14NS40 to WH16NS60?
khargy wrote: Tue Oct 27, 2026 12:52 am So I have a WH14NS40:
Revision: 1.05
yes thats the recommended fw
khargy
Post by khargy »
Not sure why this didn't work:
using MakeMKV v1.17.7 as instructed
I did:
/opt/makemkv/bin # ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:3, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_M6IJ2193306
/opt/makemkv/bin # ./makemkvcon f -d /dev/sr0 -f sdf.bin rawflash enc -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_M6IJ2193306
yes
100% Operation finished
Done successfully
I shut off and fully powered down the computer.
The firmware still reports the old information:
Revision: 1.05
Serial number: M6IJ2193306
./makemkvcon f -l
Found 1 drives(s)
00: dev_21:8, /dev/sr0, /dev/sr0
tomty89
Post by tomty89 »
IIRC if your drive was already flashed with an MK firmware, you shouldn't use "enc" in further flashing (at least not when to another MK firmware). (Some instructions indicate that you should use "main" instead. Not sure if that's different from not using anything.)
khargy
Post by khargy »
That worked! Thanks.
