Trev.bot Flash 1.0.11 | Pioneer & LG | LG currently free | $19.99 intro license | Windows/macOS/Linux
trevbot
#1 Post by trevbot » Wed Oct 14, 2026 6:26 am
LG flashing is FREE right now — $0.00. No license required.
Hi everyone,
I'm Trevor, the developer of trev.bot. Some of you have followed the Pioneer work in the existing thread. It's grown into a desktop app for flashing supported Pioneer and LG drives, and 1.0.11 is now available for Windows, macOS and Linux.
I wanted to make flashing something you could do yourself through a proper GUI. The app identifies your drive, finds compatible firmware and guides you through the process. You review the proposed change and confirm before anything is written. There are no command-line steps or firmware files to request from me.
The project grew through firmware research, testing and feedback from people here. For 1.0, I rewrote the desktop engine in Rust and added LG support. In my recent tests, an LG flash took 27 seconds and a Pioneer flash took 57 seconds. Those are individual results; your drive and connection will affect the time.
1.0.11 update
Clearer flashing progress, a Check another drive button, and easier access to logs and settings. Drive checks are faster on Windows, and this release fixes delayed check results after switching drives and unnecessary repeat restarts.
Here is a recording of an actual LG flash on my Mac. Watch the video and see the steps.
Drive support
  • Pioneer and Pioneer-based drives, including supported models with firmware from December 2022 onward.
  • LG drives, including supported LG-based ASUS and Buffalo drives.
  • Free Pioneer settings, including PureRead and reading options where supported by the drive, on Windows, macOS and Linux. Starting with 1.0.3, these need no license or activation code, even if you never flash the drive.
Exact model and firmware matter. Download the app and check your drive for free; no purchase or activation code is needed. It shows the options available for your drive.
Cross-flash and down-flash
A cross-flash installs compatible firmware from another drive model. On supported hardware, this can enable UHD support or other features.
A down-flash installs an earlier firmware version for the same model. An older version can be useful when newer firmware changes compatibility. The app shows which changes are available for your drive.
Price and license
LG flashing is currently free during the introductory period.
$19.99 introductory price (regular price $29.99) buys a personal license covering your own supported LG and Pioneer drives on up to 3 computers, with no expiry. Existing paid licenses have been upgraded at no extra charge; keep your activation code.
Downloads are available for Windows, Apple Silicon and Intel Macs, and Linux as DEB and RPM packages. App updates are free and don't require activation.
Download trev.bot flash
Help and license details
Thanks to everyone who tested early builds and sent feedback. Flashing firmware still carries risk, so follow the app's instructions and keep the drive's power and connection stable. If you need help, email help@trev.bot with the app's support report.
Trevor
I build trev.bot. LG & Pioneer drive flashing for Windows, macOS and Linux.
skyrider
Re: Trev.bot Flash 1.0 Launch | Pioneer (12/22+ FW) & LG Support | $29.99 Personal License: 3 PCs | Windows/macOS/Linux
#2 Post by skyrider » Fri Oct 16, 2026 11:41 pm
I've had the opportunity to help test various Pioneer drives and firmware configurations during the development of trev.bot flash, and I can honestly say the project has come a long way.
Trevor has been extremely responsive to feedback and bug reports, and I've watched him continuously improve both the software and drive support. I've successfully used the application on a number of drives and can highly recommend it to anyone interested in flashing, crossflashing, or managing supported Pioneer and LG drives.
Congratulations on the 1.0 release, Trevor. It's great to see all the hard work finally become a polished product. Well deserved!
Looking for a Pioneer 4K UHD drive?
Click here
Makar
#3 Post by Makar » Sat Oct 17, 2026 8:29 pm
Like Sky, I have also had the opportunity to assist Trevor since the early beta in adding support for various Pioneer drives, including S13U-X, S13UBK, 212DBK and UD03. I'm happy to say that Trevor has managed to advance optical drive flashing out of the dark ages by creating an app that is modern, user-friendly, easily accessible and cross-platform. I now have the ability to flash a drive, update its' read settings and perform MakeMKV testing, all natively within macOS.
No more forced PMing, emailing or other senseless gatekeeping
No more sketchy batch files or archaic command line knowledge required
No more being fleeced for "flashing services" @ $40-$200 per drive based on the whims of a single individual
By offering guided, full-GUI flashing support on Windows, macOS and Linux, Trev.bot Flash has opened up flashing for everyone.
Thank you Trevor!
@mike admin, Please sticky Trevor's post so it will remain visible to all. Thank you sir.
trevbot
#4 Post by trevbot » Sun Oct 18, 2026 5:34 am
Thanks, Makar and Sky! I really appreciate you both posting here, and all the time you've put into testing and sharing feedback. You've both been a huge help getting the app to this point.
trevbot
trev.bot flash 1.0.17 update
#5 Post by trevbot » Mon Oct 26, 2026 4:20 pm
trev.bot flash 1.0.17 is available for Windows, macOS and Linux.
This update adds support for more Pioneer and LG firmware versions, improves drive settings, and makes Pioneer firmware reads faster on supported adapters.
Check your drive in the app to see the options available for its exact model and firmware.
Changing settings such as PureRead on applicable Pioneer drives doesn't require a license. The version 1 intro rate is still active with Pioneer flashing at $19.99 for all of your devices (this isn't a per drive license) and LG flashing is $0.00.
Downloads · Full changelog
gwhitcombe71
Re: Trev.bot Flash 1.0.11 | Pioneer & LG | LG currently free | $19.99 intro license | Windows/macOS/Linux
#6 Post by gwhitcombe71 » Sat Oct 31, 2026 4:50 pm
trevbot cheers for the update, the faster reads sound handy... though im not sure about the "all your devices" bit, i reckon "up to 3 computers" in your first post is a bit clearer and might save you a few confused emails. to be fair that might just be me being picky (colour me a bit cautious when money's involved)
trevbot
#7 Post by trevbot » Wed Nov 04, 2026 8:15 pm
Fair point, gwhitcombe71. I meant your own drives, with the computer limit still applying. My wording could have been clearer.
A quick update from me: trev.bot 1.0.28 is out. Recent releases added support for more Pioneer/ASUS firmware versions, fixed LG flashing regressions and Pioneer empty-drive checks, and improved saved sessions and flash progress reporting. Full notes: https://trev.bot/changelog
The Black Friday special runs through November 30: supported LG flashing is free, and the personal LG + Pioneer license is $19.99 USD. Run the free Check first to see what is available for your exact drive and firmware. Details: https://trev.bot/pricing
I'm also considering batch flashing for resellers: one click to apply the same flash to all connected compatible drives. It's an idea at this stage. Would that be useful to anyone here, and how many drives would you normally have connected? Any other features or changes you'd like to see?
