Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
turbov6camaro wrote: Sat Oct 24, 2026 5:04 pm Thanks again for the help. One more disc below - the keydb has an entry for this disc ID, but MakeMKV still reports "The volume key is unknown for this disc", so I'm submitting the dump. As before, the full MKB_RO.inf is inside the .tgz:
Disc type: UHD (4K Ultra HD Blu-ray) - Minions: The Rise of Gru, label MINIONS_THE_RISE_OF_GRU_UPK75
Disc ID: 81299CD590828AB94E940B09939D020650BE9568
Disc dump filename: MKB20_v76_Minions-_The_Rise_of_Gru_A895.tgz
Thanks for the submission, your disc now has a complete record in the public keydb.
MakeMKV will only process discs if the volume unique key (VUK) is known. This corresponds to the keydb field after " | V | ". Your disc previously had the unit key but no other fields, so the MakeMKV error you observed was to be expected.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
hulahoo
Post by hulahoo »
quadrant
Post by quadrant »
The Italian Job
Disc type: BD-ROM UHD
Disc ID: 8E6BF25201017E926F5A098B2176B740141C8307
Disc dump filename: MKB20_v77_The_Italian_Job_2B71.tgz
Drive: PIONEER BD-RW BDR-UD04
Drive firmware: 1.14
LibreDrive status: Enabled
MKB_RO.inf link: https://transfer.it/t/m2hmcvonwBbC
Disc dump link: https://transfer.it/t/zB1kwnx1kbjL
VarHD
Post by VarHD »
Little Shop of Horrors (4K), Steelbook
Disc type: UHD
Disc ID: 7e55fc35a21ead6b22a2c7b18cb1902d095f56dc
Disc dump filename: MKB20_v82_LITTLESHOPOFHORRORS_2D36
Drive: ASUS BW-16D1HT
Drive firmware: 3.01
MKB_RO.inf link: https://mega.nz/file/XZ1GECAR#OsA7PZ__e ... afPHpmT6WM
Disc dump link: https://mega.nz/file/bMcUESZL#d5ADtI9PL ... vADUmzlThI
falconchips
Post by falconchips »
Minions&monsters UHD (Spain)
Disc type: UHD (label MinionsAndMonsters_UPK1)
Disc ID: 0x084EEBBA67AE484F136B6477A5AB8406CFFFE826
Disc dump filename: MKB20_v82_Minions_and_Monsters_5AD2.tgz
Is your MKB_RO.inf file size at least 2MB? Yes (128 MB)
MKB_RO.inf link: https://drive.google.com/file/d/1_ehdOh ... sp=sharing ((copied directly from the disc)
Disc dump link: https://drive.google.com/file/d/1CR-db2 ... sp=sharing
turbov6camaro
Post by turbov6camaro »
Thanks for all the keys so far - everything has ripped perfectly. Here's a bigger batch from today's mail (11 discs). Every dump was packed with the full MKB_RO.inf inside the .tgz, as suggested.
Disc type: UHD (4K Ultra HD Blu-ray) - Indiana Jones and the Dial of Destiny, label INDIANA_JONES_DIAL_OF_DESTINY
Disc ID: 9211126105E800EC5FD9BC243164AE3B3040B149
Disc dump filename: MKB20_v77_INDIANA_JONES_AND_THE_DIAL_OF_DESTINY_8C1B.tgz
Drive: LG BP60NB10
Drive firmware: 1.02
Is your MKB_RO.inf file size at least 2MB? Yes (5 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1YWyuMP ... TMt7Y/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1YWyuMP ... TMt7Y/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Men in Black (1997), label MEN_IN_BLACK
Disc ID: 2584831F51DED040F0A3ACE7435526731DF1EAAE
Disc dump filename: MKB20_v61_Men_in_Black_(1997)_31AB.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1wIl9TK ... H3CB4/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1wIl9TK ... H3CB4/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Men in Black 3, label MEN_IN_BLACK_3
Disc ID: 2231FE41F38B7EB9C95E41A120BD6CC23B8F1307
Disc dump filename: MKB20_v61_Men_In_Black_3_ADD3.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1MipeTU ... vmOXh/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1MipeTU ... vmOXh/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Back to the Future Part III (40th Anniversary), label BACK_TO_THE_FUTURE_PART_III
Disc ID: 7D88D6D8776DE1B46BE4822ADE229121F0200F42
Disc dump filename: MKB20_v76_Back_to_the_Future_Part_III_6BB9.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1bQFUYV ... RrcZ5/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1bQFUYV ... RrcZ5/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Home Alone (Ultimate Collector's Edition), label HOME_ALONE
Disc ID: 515C3F7EC1A15A9F96DCDA9168711860A48FCD01
Disc dump filename: MKB20_v76_Home_Alone_E24F.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1slMhYT ... Vn73j/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1slMhYT ... Vn73j/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Bad Boys (1995), label BAD_BOYS_1995
Disc ID: 473BB6881AF779DC98E6E1CCA464EEC225D43BA8
Disc dump filename: MKB20_v61_Bad_Boys_(1995)_4317.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1q5pV4e ... aCY0F/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1q5pV4e ... aCY0F/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Bad Boys II, label BAD_BOYS_II
Disc ID: F4184FED4350CB12C932C92C343CDD956BDDEFD4
Disc dump filename: MKB20_v61_Bad_Boys_II_1D2B.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1GdQVlE ... 6EkHi/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1GdQVlE ... 6EkHi/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Bad Boys for Life, label BAD_BOYS_FOR_LIFE
Disc ID: 68F4319B9EA35CF61C70C4B7E46C530C18663902
Disc dump filename: MKB20_v68_Bad_Boys_for_Life_85DF.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1GSEqgO ... GfYBU/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1GSEqgO ... GfYBU/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Ghostbusters: Afterlife, label GHOSTBUSTERS_AFTERLIFE
Disc ID: 44E61990DDA090DFBBC498667265D6A7956BFAE8
Disc dump filename: MKB20_v77_Ghostbusters-_Afterlife_FA27.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1ARzpIs ... wNr9T/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1ARzpIs ... wNr9T/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Ghostbusters: Frozen Empire, label GHOSTBUSTERS_FROZEN_EMPIRE
Disc ID: C99263C470D58AE5612E70875B9FA71E8B0A60E7
Disc dump filename: MKB20_v77_Ghostbusters-_Frozen_Empire_E133.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/18ZfIxx ... fcKKw/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/18ZfIxx ... fcKKw/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Jaws 3, label Jaws3_UPK1
Disc ID: CC73223572D0ADDB192F8459D958A3A1724BAC3D
Disc dump filename: MKB20_v77_Jaws_3_DBCD.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1oulaye ... iwdU3/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1oulaye ... iwdU3/view (same zip)
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Ghostbusters-_Afterlife_FA27
*MKB20_v77_Ghostbusters-_Frozen_Empire_E133
*MKB20_v77_The_Italian_Job_2B71
*MKB20_v82_Bluebeard_6B2E
*MKB20_v82_HEATHERS_156E
MKB20_v82_JOY_RIDE_C751
*MKB20_v82_LITTLESHOPOFHORRORS_2D36
MKB20_v82_Project_Hail_Mary_F321
KeyDB Priority List
FlamboyantSlowpoke
Post by FlamboyantSlowpoke »
keydb_helper wrote: Sun Oct 25, 2026 1:15 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
Thanks so much for your work, the mixed aspect PHM rips perfectly on makeMKV and can't wait to watch it on my VR set later!
mikenuun
Post by mikenuun »
Disc ID: effa18cd63ef8e7c2f1b9c7748f86e678ec8cabd
Disc dump filename: MKB20_v82_Walkyrie_1B50.tgz
Drive: lg bh16ns55
MKB_RO.inf link: (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc) https://drive.google.com/file/d/11NRXEg ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1ZX27tk ... sp=sharing
mczocker32
Post by mczocker32 »
Disc type: UHD
Disc ID: 0x2F9EA92A59BBE71A46D08AFEA909D454E091E826
Disc dump filename: MKB20_v82_United_93_DD3F.tgz
Drive: HL-DT-ST BD-RE WH16NS40
Drive firmware: 1.05
MKB_RO.inf link: https://drive.google.com/file/d/1ix_a1H ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1F4-iZN ... sp=sharing
keydb_helper
mczocker32 wrote: Sun Oct 25, 2026 10:10 am Disc type: UHD
Thanks for the submission mczocker32, your disc has been added to the public keydb.
KeyDB Priority List
RandomSelf
Dump submitted - La Chambre d’à Côté (2025) (Pedro Almodovar) [3956]
Post by RandomSelf »
Greetings all,
Disc type : HD
Disc ID : E2B08125BF026E6FD8988CE0F5596A4FCE66029A
Disc dump filename : MKB_v82_BLU-RAY_3956
Drive : BH16NS40
Drive firmware : 1.05
LibreDrive status : Enabled
Did you sync the public keydb within the last 15 minutes : Yes
Submission links are accessible in incognito/private browsing : Verified
MKB_RO.inf link : https://drop.chapril.org/download/87855 ... gdzQ-ZHoyg
Disc dump link : https://drop.chapril.org/download/cfd01 ... sqkEapf1xw
All the best,
RandomSelf
keydb_helper
mikenuun wrote: Sun Oct 25, 2026 7:34 am Disc type: UHD (4K Ultra HD Blu-ray)
RandomSelf wrote: Sun Oct 25, 2026 12:55 pm Disc type : HD
Thanks for the submissions. Both discs have been added to the public keydb.
KeyDB Priority List
cromtoss
Post by cromtoss »
Severin's 4K UHD Release of What Have You Done to Solange:
Disc type: UHD
Disc ID: DC7FCD4809E5EF97D2F02C51FCA45BF54A4F910E
Disc dump filename: MKB20_v82_SOLANGE_UHD_8C91.tgz
Drive: PIONEER BD-RW BDR-XS07U
Drive firmware: PIONEER BDR-BDS7 1.01/ID05
MKB_RO.inf link: (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc) https://drive.google.com/file/d/1XiFO-3 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1zeaw3Q ... sp=sharing
isp1985
Post by isp1985 »
Disc type : UHD
Disc ID : DC7FCD4809E5EF97D2F02C51FCA45BF54A4F910E
Disc dump filename : MKB20_v82_SOLANGE_UHD_8C91.tgz
Drive : LG BU40N
Drive firmware : 1.03
Submission links are accessible in incognito/private browsing : Yes
MKB_RO.inf link : https://drive.google.com/file/d/1_4i9FG ... sp=sharing
Disc dump link : https://drive.google.com/file/d/1i73xSw ... sp=sharing
