Rambo: Last Blood can't be read
SimplyLearning
Post by SimplyLearning » Sat Oct 24, 2026 2:56 am
Is or has anyone had issues with the Amazon exclusive Rambo Complete Collection boxset, particularly the 5th film, Rambo: Last Blood. My Pioneer BDR-XS07U can't read my disc. It appears to be in perfect condition however I still did a careful clean of the disc just in case because sometimes doing this has solved similar issues on other discs however that had no effect on this one. All of the other discs in the set were read and ripped without a single issue. All discs were perfectly seated on their anchors when I opened the package. Even outside of MakeMKV, Windows can't read the disc in the drive at all, it just tries a number of times and then ejects it.
Re: Rambo: Last Blood can't be read
Post by MartyMcNuts » Sat Oct 24, 2026 5:35 am
SimplyLearning wrote: Sat Oct 24, 2026 2:56 am Hello,
1. Clean the disc, even if it looks pristine.
2. If that doesn't help, try a different drive. Some drives just don't like some discs.
SimplyLearning
Post by SimplyLearning » Sat Oct 24, 2026 1:58 pm
MartyMcNuts wrote: Sat Oct 24, 2026 5:35 am
Thanks for the suggestions. I had cleaned it yesterday to no effect. I just took the disc to my standalone player, an Oppo BDP-205 and it plays fine in there. Unfortunately my laptop internal drive can not read 4K discs so I'm unable to use that and am stuck with just my external Pioneer BDR-XS07U.So it sucks not being able to rip this disc.
Savhage
Post by Savhage » Mon Oct 26, 2026 3:04 am
I'm running into the same thing. Seems the encryption was changed for this release. Hoping it is decrypted soon. For reference:
The AACS dump file "****MakeMKV/MKB20_v82_Rambo_-_Last_Blood_22EC.tgz" was successfully sent for analysis
SimplyLearning
Post by SimplyLearning » Tue Oct 27, 2026 2:14 am
Ah interesting. Thanks for posting. At least I'm not the only one. Hopefully we'll get to rip it soon.
Was just about to purchase another drive from another brand with hopes that would do it. Could have been a lot of money unnecessarily spent.
Post by MartyMcNuts » Tue Oct 27, 2026 3:56 am
Savhage wrote: Mon Oct 26, 2026 3:04 am I'm running into the same thing. Seems the encryption was changed for this release. Hoping it is decrypted soon. For reference:
Did you create a post in the public keydb submissions thread? It's usually faster.
keydb_helper
Post by keydb_helper » Tue Oct 27, 2026 8:34 am
SimplyLearning wrote: Tue Oct 27, 2026 2:14 am Ah interesting. Thanks for posting. At least I'm not the only one. Hopefully we'll get to rip it soon.
Your issue is not the same as what Savhage has encountered:
The key is not currently available for his disc but the disc was still visible to both his operating system and MakeMKV. That level of visibility is a prerequisite for generating a disc dump file.
SimplyLearning wrote: Sat Oct 24, 2026 2:56 am Even outside of MakeMKV, Windows can't read the disc in the drive at all, it just tries a number of times and then ejects it.
Savhage will be able to process his disc after the keys are available. But the key availability won't help your disc drive to detect and read the disc.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
SimplyLearning
Post by SimplyLearning » Wed Oct 28, 2026 1:58 pm
Ah nuts, yeah good point. My drives can't read the disc at all. The decryption thing I did encounter this past summer with a couple of Stranger Things discs, the discs were read but just couldn't be decrypted and produced a decryption error from MakeMKV. With the Rambo disc the disc drive just ejects the disc after trying to read it a number of times.
gwhitcombe71
Post by gwhitcombe71 » Fri Oct 30, 2026 12:59 pm
SimplyLearning wrote:With the Rambo disc the disc drive just ejects the disc after trying to read it a number of times.
SimplyLearning, sounds like the disc is giving your drive the cold shoulder... proper stubborn, like my Defender on a frosty morning 😂 if the Oppo plays it fine then i reckon its just that drive being fussy (or the disc being a bit wonky in a way you cant see), so id hang on before buying another one.
