THE HEROIC TRIO
Disc type: BD-ROM UHD
Disc ID: d06b614c631c17de24f41822349c45c242294b65
Disc dump filename: MKB20_v82_THE_HEROIC_TRIO_35A2.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
LibreDrive status: Enabled
MKB_RO.inf link: https://transfer.it/t/RbAho2hzlb7A
Disc dump link: https://transfer.it/t/rBBtVm4hUJiR
EXECUTIONERS - THE HEROIC TRIO 2
Disc ID: 2baec894bc4091a47d9d09ef97f474f6159bc5bf
Disc dump filename: MKB20_v82_EXECUTIONERS_THE_HEROIC_TRIO_2_FF2A.tgz
MKB_RO.inf link: https://transfer.it/t/dYwgQmg1CL5J
Disc dump link: https://transfer.it/t/J6bCor4zEDKB
Public KeyDB Disc Submissions
cjw73
Disc ID: 889A306D03059871C618D247034C1A6231452662
Disc type: UHD
Disc dump filename: MKB20_v82_THE_END_OF_OAK_STREET_AB1C.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Disc dump link: https://drive.proton.me/urls/93CFZXG1KC#7i5Gj1cyBgqO <-standard
i also copied the full MKB_RO.inf 128mb file, not sure if it makes a difference when it's not a stub file....
https://drive.proton.me/urls/B14RXEW74M#SOgc9dl57Tqe <- full
Disc type: UHD
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_CABAL_theatrical_61C6
*MKB20_v82_EXECUTIONERS_THE_HEROIC_TRIO_2_FF2A
MKB20_v82_LITTLESHOPOFHORRORS_301E
*MKB20_v82_SottoShock_UHD_D6E6
*MKB20_v82_THE_END_OF_OAK_STREET_AB1C
*MKB20_v82_The_Furious_9D68
*MKB20_v82_THE_HEROIC_TRIO_35A2
*MKB20_v82_The_Shining_E1D8
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Skolven
Disc type: UHD
Disc ID: 0x7D4B793A94E13A84E94F12CDE8F2AE8E1025B122
Disc dump filename: MKB20_v82_UN_HOMME_ET_UNE_FEMME_UHD_BEFA.tgz
Drive: Verbatim 43888 (External, HL-DT-ST BD-RE BU40N)
Drive firmware: 1.03
Is your MKB_RO.inf file size at least 2MB? Yes, 128 MiB, copied directly from the original disc.
MKB_RO.inf link: https://transfert.free.fr/APhR43g
Disc dump link: https://transfert.free.fr/APhR43g
Both links point to the same ZIP containing both files.
Thank you!
Thank you!
turbov6camaro
Thanks for keying The Incredibles, Backdraft and Waterworld - all three ripped perfectly. One more disc below. This dump was packed with the full MKB_RO.inf inside the .tgz, as suggested:
Disc type: UHD (4K Ultra HD Blu-ray) - Now You See Me, label NOW_YOU_SEE_ME
Disc ID: ACDBE86DDB772D56066FD65721F6F6F12E84043B
Disc dump filename: MKB20_v60_Now_You_See_Me_F309.tgz
Drive: LG BP60NB10
Drive firmware: 1.02
Is your MKB_RO.inf file size at least 2MB? Yes (128 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1cqcSTF ... dF4TK/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1cqcSTF ... dF4TK/view (same zip)
Drive: LG BP60NB10
BigDaddyJ
Disc type: UHD (4K Ultra HD Blu-ray) - Five Nights At Freddy's - Night Shift Edition, label FIVENIGHTSATFREDDYS_UPK75
Disc ID: 0xDB00425BC90821BC7C0AE11FB1AA15C787A779CC
Disc dump filename: MKB20_v77_Five_Nights_at_Freddy's_5C45.tgz
Drive: PIONEER BD-RW BDR-212U
Drive firmware: 1.01
Is your MKB_RO.inf file size at least 2MB? Yes - 128MB copied from disc
MKB_RO.inf link https://drive.google.com/file/d/1NzBXd9 ... drive_link
Disc dump link: https://drive.google.com/file/d/1zDyg0E ... drive_link
keydb_helper
*MKB20_v82_ANGELS_EGG_42BA
*MKB20_v82_MARIE_ANTOINETTE_6A0E
*MKB20_v82_Undertone_E000
*MKB20_v82_UN_HOMME_ET_UNE_FEMME_UHD_BEFA
Dimon
Chernobyl – Disc 1
Disc type: UHD
Disc ID: 0x99132886EE4B7A56038E56A87E760563E944B1EC
Disc dump filename: MKB20_v82_Chernobyl_-_Disc_1_-_UHD_345A.tgz
Drive: HL-DT-ST BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1RaZBMh ... p=drivesdk
Disc dump link: https://drive.google.com/file/d/1WKYJ3P ... p=drivesdk
Disc type: UHD
Dimon
Chernobyl – Disc 2
Disc type: UHD
Disc ID: 0xD0D13C7F3242F80EA1165A8826658A84CAC22BD8
Disc dump filename: MKB20_v82_Chernobyl_-_Disc_2_-_UHD_C6AC.tgz
MKB_RO.inf link: https://drive.google.com/file/d/14JuWtw ... p=drivesdk
Disc dump link: https://drive.google.com/file/d/146rNEv ... p=drivesdk
Disc type: UHD
JTXWYLM
回复:公钥数据库光盘提交
Hello, this is the Steelbook dump file of Project Hail Mary. I hope to see this 4K UHD key in the next key library update. Thank you very much.
Disc type: UHD
Disc ID:981ADF4A4C19C4AAA1E87DBD580F9025536CD3BC
Disc dump filename: MKB20_v82_Project_Hail_Mary_195D.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1bvZXUS ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1QnlyFf ... drive_link
Disc type: UHD
Drive: BD-RE BU40N
keydb_helper
Dimon wrote: Sat Oct 24, 2026 9:58 am Chernobyl – Disc 1
Disc type: UHD
Thanks for following the submission template and welcome to the forum Dimon. Both of your Chernobyl discs have been added to the public keydb.Dimon wrote: Sat Oct 24, 2026 9:59 am Chernobyl – Disc 2
Disc type: UHD
Hey JTXWYLM, thanks for giving it a crack but your disc was added to the public keydb on October 13. Your MKB_RO.inf file was also only 56 bytes, so I'm not sure why you claimed it was above 2MB. Please take the time to carefully read the opening post of this thread.JTXWYLM wrote: Sat Oct 24, 2026 10:50 am Hello, this is the Steelbook dump file of Project Hail Mary. I hope to see this 4K UHD key in the next key library update. Thank you very much.
Disc type: UHD
Drive: BD-RE BU40N
megtvash
Heathers
Disc type: UHD
Disc ID: 5D1042B7194569F836214A99C0D6A01935736598
Disc dump filename: MKB20_v82_HEATHERS_156E.tgz
Drive: HL-DT-STBD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/192Nemj ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13jWWqj ... sp=sharing
Disc type: UHD
FlamboyantSlowpoke
Hello, here is the template completed for the new mixed aspect ratio version of Project Hail Mary from its steelbook release:
Disc type: UHD
Disc ID: 677056832c271566abd2afa59427745682ba2676
Disc dump filename: MKB20_v82_Project_Hail_Mary_F321-1.tgz
MKB_RO.inf link: https://drive.google.com/file/d/10IbjZ1 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KQSrOq ... sp=sharing
Disc type: UHD
cromtoss
Disc type: UHD
Disc ID: 2060F57107E2A5A5FDFE5E0D67233CACEAA9C082
Disc dump filename: MKB20_v82_Bluebeard_6B2E.tgz
Drive: PIONEER BD-RW BDR-XS07U
Drive firmware: PIONEER BDR-BDS7 1.01/ID05
MKB_RO.inf link: (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc) https://drive.google.com/file/d/1m-qJ7H ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kSOxNl ... sp=sharing
turbov6camaro
Thanks again for the help. One more disc below - the keydb has an entry for this disc ID, but MakeMKV still reports "The volume key is unknown for this disc", so I'm submitting the dump. As before, the full MKB_RO.inf is inside the .tgz:
Disc type: UHD (4K Ultra HD Blu-ray) - Minions: The Rise of Gru, label MINIONS_THE_RISE_OF_GRU_UPK75
Disc ID: 81299CD590828AB94E940B09939D020650BE9568
Disc dump filename: MKB20_v76_Minions-_The_Rise_of_Gru_A895.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/12pM88d ... 4eUkm/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/12pM88d ... 4eUkm/view (same zip)
Drive: LG BP60NB10
