Pioneer BDR-UD03 UHD possibility
undeadmonkey
Re: Pioneer BDR-UD03 UHD possibility
#1426 Post by undeadmonkey » Wed Oct 21, 2026 10:25 pm
Coopervid wrote: Wed Oct 21, 2026 8:53 pm
undeadmonkey wrote: Wed Oct 21, 2026 6:44 pm Hi i have this drive,
OS device name: /dev/rdisk22
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number: UHDL629633WL
Firmware date: 2018-04-26
Could i have the files to flash it?
Thanks for your service!
Tell me your OS and hardware
sorry i'm new to this, not sure what you mean by hardware. i bought an old imac to run this off of and i've attached a screenshoot of the specs, the drive i attached with one of those cheap dvd enclosures from amazon. something similar to this. https://www.amazon.com/Zunate-External- ... 180&sr=8-3
#1427 Post by Coopervid » Thu Oct 22, 2026 9:30 am
undeadmonkey wrote: Wed Oct 21, 2026 10:25 pm
Revision: 1.21
OS is understood. I meant Intel or ARM based PC. I will send both packages to you by PM:
mrgork
#1428 Post by mrgork » Sat Oct 24, 2026 3:32 am
I have the following two drives:
Drive 1:
OS device name: F:
Revision: 1.14
Serial number: BDDL486975WL
Firmware date: 2020-06-15
Highest AACS version: 66
Drive platform: RS8511
Firmware version: 1.14
Drive 2:
OS device name: F:
Revision: 1.11
Serial number: TGDL329653WL
Firmware date: 2018-11-28
Firmware version: 1.11
I'm also looking for the files to flash it.
Thank you in advance.
#1429 Post by Billycar11 » Sat Oct 24, 2026 12:45 pm
mrgork wrote: Sat Oct 24, 2026 3:32 am Hello,
Drive 1:
OS device name: F:
Revision: 1.14
Drive 2:
OS device name: F:
Revision: 1.11
Sure just email me
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
mrgork
#1430 Post by mrgork » Sun Oct 25, 2026 4:15 am
Worked perfectly! Thank you Billy! :D :D :D :D :D
arnostk
#1431 Post by arnostk » Mon Oct 26, 2026 7:40 pm
Hi Coopervid,
I recently purchased a Verbatim 43889 external Blu-ray drive with a Pioneer BDR-UD03 inside.
I would like to enable UHD Blu-ray reading, if possible.
Here is my MakeMKV drive information:
**Drive Information**
- Manufacturer: PIONEER
- Product: BD-RW BDR-UD03
- Revision: 1.14
- Firmware date: 2020-06-15
- Bus encryption flags: 1B
**LibreDrive Information**
- Status: Enabled
- Drive platform: RS8511
- Firmware name: PIONEER BDR-US03
- Firmware type: Original (unpatched)
- Firmware version: 1.14
Would it be possible to get your help with the appropriate firmware and flashing tool for this drive?
Thank you very much for your time and help!
Goobsters
#1432 Post by Goobsters » Mon Oct 26, 2026 10:59 pm
Hello, friends!
I was wondering if I can get the files to allow Blu-Ray UHD for my drive, so I can flash it on windows. (Information below) :D
Thank you,
- GOOB
Verbatim: External All-in-One Optical Writer (#71094)
Specs:
OS device name: F:
Revision: 1.14
Serial number: Redacted
#1433 Post by Billycar11 » Mon Oct 26, 2026 11:43 pm
Goobsters wrote: Mon Oct 26, 2026 10:59 pm Hello, friends!
Thank you,
- GOOB
Specs:
OS device name: F:
Revision: 1.14
Sure just email me
Goobsters
#1434 Post by Goobsters » Tue Oct 27, 2026 6:32 am
Billycar11 wrote: Mon Oct 26, 2026 11:43 pm
Thank you,
- GOOB
Specs:
OS device name: F:
Revision: 1.14
Sure just email me
Thank you so much !!
davuk1972
#1435 Post by davuk1972 » Fri Oct 30, 2026 6:11 pm
Hi
I'm new here, can anyone support with this drive firmware and flashing tool,
I've been told its an old drive which shold be capable of reading UHD Disks having a decrypted BDR-UD04 firmware?
Thanks in advance
David
OS device name: I:
Revision: 1.05
Serial number: PKDL068368WL
Firmware date: 2015-11-24
Drive platform: RS8510
Firmware version: 1.05
Disc Information
Data capacity: 44.52 Gb
Disc type: BD-ROM
Number of layers: 2
mattjackson86
#1436 Post by mattjackson86 » Fri Oct 30, 2026 11:07 pm
Joris222
#1437 Post by Joris222 » Mon Nov 02, 2026 6:07 pm
I also have a Pioneer BDR-UD03. I wanted to make it UHD friendly I flashed the drive with the files for the BDR-UD03. Thu Gui program said success, but nothing changed. It still sees BD only not UDH.
Should i use the BDR-UD04 flash files?
Any advice would be appreciated.
Thanks in advance, Joris222
#1438 Post by Billycar11 » Mon Nov 02, 2026 9:47 pm
Joris222 wrote: Mon Nov 02, 2026 6:07 pm I also have a Pioneer BDR-UD03. I wanted to make it UHD friendly I flashed the drive with the files for the BDR-UD03. Thu Gui program said success, but nothing changed. It still sees BD only not UDH.
Sure just email me
1q59xwol9
#1439 Post by 1q59xwol9 » Tue Nov 03, 2026 9:59 am
I cross flashed my UD03 with the freemkv flasher.
I downloaded this flashing tool https://freemkv.org/firmware/flash/
and this firmware https://freemkv.org/firmware/find/?driv ... ision=1.14
Go to the flash tab, choose firmware and pick the file. Press Flash now and it will run a few tests and back up the original firmware, then confirm if you want to proceed. It will flash and then run some tests to check it's working and it's done.
Before:
OS device name: G:
Revision: 1.10
Serial number: removed
Firmware date: 2017-04-18
Firmware version: 1.10
After:
OS device name: G:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Drive platform: RS8A10
kyzersoze1974
#1440 Post by kyzersoze1974 » Tue Nov 03, 2026 11:21 am
Hi Coopervid,
I have a Verbatim LPUBAA external Blu-ray drive with the following specifications:
Model: PIONEER BDR-UD03
Firmware: 1.14 (2020-06-15)
LibreDrive: Enabled
Could you please provide the appropriate firmware and instructions to enable 4K UHD Blu-ray reading?
Thanks for your help!
