not reading bluray (but on windows yes)
kapqa
#1 Post by kapqa » Tue Jul 28, 2026 8:22 pm
Hello ,
have compiled latest version according to your guide for ubuntu
on devuan 6 - it seem function ok,
however, on this older drive (LG GGC-H20N) it would not detect the bluay disc
when i start the program in windows 7 it would.
could it be that the guide need some adaptation to function also good with older drive or what am i missing on linux?
thank you very much.
georgesgiralt
Re: not reading bluray (but on windows yes)
#2 Post by georgesgiralt » Wed Jul 29, 2026 6:37 am
Hi !
Try to put the disc in the drive and wait until it shows on Linux *before* starting Makemkv. It may be a difference. If not ask again.
kapqa
#3 Post by kapqa » Thu Jul 30, 2026 4:13 pm
think there are some error involved,
had downloaded now the sdf.bin file and put into .makemkv folder,
but upon opening program , it gets deleted.
error log like
001003:0020 DEBUG: Code 0 at KG]XmhY0,A.yRLL3a@B-s>:29393631
No  SDF v0a6: HL-DT-ST_BDDVDRW_GGC-H20N_1.01_20070918123456_K1779482558
SDF id v0a6: HL-DT-ST_BDDVDRW_GGC-H20N_1.01_20070918123456_K1779482558
SDF auto v0a6: HL-DT-ST_BDDVDRW_GGC-H20N_1.01_20070918123456_K1779482558
tomty89
#4 Post by tomty89 » Sun Aug 02, 2026 4:20 pm
Put the following line in ~/.MakeMKV/settings.conf:
sdf_Stop = "HL-DT-ST_BDDVDRW_GGC-H20N_1.01_20070918123456_K1779482558"
kapqa
#5 Post by kapqa » Wed Aug 05, 2026 2:52 pm
thank you,
this has been helpful, now it functions also with this older drive!
problem solved!
AJSarley223
#6 Post by AJSarley223 » Thu Oct 22, 2026 8:13 am
kapqa wrote: Thu Jul 30, 2026 4:13 pm error log like
tomty89 wrote: Sun Aug 02, 2026 4:20 pm Put the following line in ~/.MakeMKV/settings.conf:
Thank you SOOOO much; you saved me from buying a $300 slim drive.
Mods, PIN this thread!
maddsmish
#7 Post by maddsmish » Sat Oct 31, 2026 3:29 am
Oh yes, this fixed one of my old drives for me with a new fully-licensed install of MakeMKV 2.0 on Linux. Someone please pin this. You have to turn on debug logging and then go look for the SDF string to disable in the settings file, but it totally works. :)
gwhitcombe71
#8 Post by gwhitcombe71 » Sat Oct 31, 2026 6:22 pm
proper good find this, saves binning a perfectly decent old drive... reckon it belongs in a sticky 🙂
