Pioneer BDR-UD03 UHD possibility
lucclu
Re: Pioneer BDR-UD03 UHD possibility
I have a couple more drives to see if they can be flashed.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number: PJDL294237WL
Firmware date: 2015-05-14
Highest AACS version: 82
Drive platform: RS8510
Firmware version: 1.03/ID19
OS device name: E:
Revision: 1.03
Serial number: PHDL272227WL
Thank you!
OS device name: E:
Revision: 1.03
OS device name: E:
Revision: 1.03
Thank you!
lediable
Hi Coopervid, I think I got overlooked (or I'm the unwanted stepchild?) in the swarm of recent requests for a flash on this drive. Appreciate the help here. Thanks!
lediable wrote: Tue Sep 29, 2026 9:14 pm Hello kind souls,
Add me to the group of Verbatim 43890 owners looking for UHD capability:
OS device name: E:
Revision: 1.14
Serial number: DDDL529578WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Classytimes
Hey Coopervid, can I ask for help with a couple drives I have? Thank you a bunch if you can!!
OS device name: G:
Revision: 1.21
Firmware date: 2018-04-26
Firmware version: ID19
OS device name: G:
Revision: 1.03
OS device name: G:
Product: BD-RW BDR-UD03D
Revision: 1.00
Firmware date: 2014-05-14
Firmware version: 1.00/ID84
OS device name: G:
Revision: 1.21
OS device name: G:
Revision: 1.03
OS device name: G:
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directlylediable wrote: Tue Sep 29, 2026 9:14 pm Hello kind souls,
OS device name: E:
Revision: 1.14
see below for email
sure email me that info and all others email me no need to post your info here just reach out to me directlylucclu wrote: Thu Oct 08, 2026 2:59 am I have a couple more drives to see if they can be flashed.
OS device name: E:
Revision: 1.03
OS device name: E:
Revision: 1.03
Thank you!
see below for email
PM sent.lucclu wrote: Thu Oct 08, 2026 2:59 am I have a couple more drives to see if they can be flashed.
OS device name: E:
Revision: 1.03
OS device name: E:
Revision: 1.03
Thank you!
PM sent.lediable wrote: Thu Oct 08, 2026 10:19 pm Hi Coopervid, I think I got overlooked (or I'm the unwanted stepchild?) in the swarm of recent requests for a flash on this drive. Appreciate the help here. Thanks!
OS device name: E:
Revision: 1.14
PM sent.Classytimes wrote: Fri Oct 09, 2026 3:44 am Hey Coopervid, can I ask for help with a couple drives I have? Thank you a bunch if you can!!
OS device name: G:
Revision: 1.21
OS device name: G:
Revision: 1.03
OS device name: G:
Revision: 1.00
sakamdi
I got an external reader for the bluray drive and can now report that MakeMKV reports the following:Coopervid wrote: Mon Oct 05, 2026 9:35 pmAgain the label doesn't count.sakamdi wrote: Mon Oct 05, 2026 9:16 pmHi again Coopervid,Coopervid wrote: Sun Oct 04, 2026 10:53 pm
Sorry buddy! The label doesn't count. What counts is what Makemkv is reporting.
Thanks for your patience. I think there's an unusual edge case here that may explain the discrepancy.
This thread from last week appears to document essentially the same situation:
viewtopic.php?t=42497
That drive also reported to MakeMKV as HL-DT-ST BP55EB40 revision 1.00, and SDFTool reported MT1959 Platform: NO. After opening it, the mechanism was identified as a Pioneer BDR-UD03TBD HW/FW 1.00, and MartyMcNuts identified it as Pioneer/RS8511 hardware.
Mine likewise reports BP55EB40 1.00 in MakeMKV, SDFTool says MT1959 Platform: NO, but the physical mechanism is labelled Pioneer BDR-UD03TBD HW/FW 1.00.
So I'm reluctant to try LG firmware on it. Could this be the same unusual configuration as that other drive?
OS device name: J:
Revision: 1.00
Serial number: OBDL038140WL
PM sent.sakamdi wrote: Fri Oct 09, 2026 1:25 pmI got an external reader for the bluray drive and can now report that MakeMKV reports the following:Coopervid wrote: Mon Oct 05, 2026 9:35 pmAgain the label doesn't count.sakamdi wrote: Mon Oct 05, 2026 9:16 pm
Hi again Coopervid,
OS device name: J:
Revision: 1.00
chrisp
I have a Verbatim 71097 external Blu-ray writer containing a Pioneer BDR-UD03 drive.
My MakeMKV information is:
- Drive: PIONEER BD-RW BDR-UD03
- Firmware revision: 1.14
- Firmware date: 2020-06-15
- Drive platform: RS8511
- Firmware name: PIONEER BDR-US03
- Firmware type: Original (unpatched)
- LibreDrive status: Enabled
Regular Blu-ray movies work correctly in MakeMKV. However, when I insert a 4K UHD Blu-ray movie, MakeMKV reports "No disc inserted."
Could you help me obtain the correct UHD-compatible firmware and flashing instructions for this drive?
I am using Windows.
Thank you!
I am using Windows.
Thank you!
Sure just email mechrisp wrote: Sat Oct 17, 2026 3:56 pm Hi,
I am using Windows.
Thank you!
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
undeadmonkey
Hi i have this drive,
OS device name: /dev/rdisk22
Current profile: DVD-ROM
Revision: 1.21
Serial number: UHDL629633WL
Could i have the files to flash it?
Thanks for your service!
Revision: 1.21
Tell me your OS and hardwareundeadmonkey wrote: Wed Oct 21, 2026 6:44 pm Hi i have this drive,
Revision: 1.21
Sure just email meundeadmonkey wrote: Wed Oct 21, 2026 6:44 pm Hi i have this drive,
Revision: 1.21
