Demux MKV Audio to AVC/AC3/DTS/ec with a Mac
DUB RAY
Post by DUB RAY » Fri May 25, 2012 11:26 pm
Hopefully this will be a quick question and my Subject line will provide easy reference for future searches.
I have a Blu Ray Disc, that I was able to successfully convert to MKV. What I need help understanding is the process and the best software solution to demux the MKV to create the encoded audio files. Plus Demuxing 5.1 and or creating the streams.
I have seen a few software names thrown out, but could not figure out how they worked. Plus being on a mac creates more of a challenge.
Any help will be greatly appreciated.
DR
Smithcraft
Re: Demux MKV Audio to AVC/AC3/DTS/ec with a Mac
Post by Smithcraft » Sat May 26, 2012 8:09 pm
Tsmuxer is the only one that I can think of for demuxing and getting the streams into files.
I don't know of anything for splitting up a 5.1 file. Audacity can read AC3 but it will convert it, which takes memory and time.
SC
Romansh
Post by Romansh » Sat May 26, 2012 9:07 pm
Smithcraft wrote:Tsmuxer is the only one that I can think of for demuxing and getting the streams into files.
mkvextract (part of Mkvtoolnix). Command-line only, though.
setarip_old
Post by setarip_old » Thu May 31, 2012 6:45 pm
I'm fairly certain that both/all of the programs mentioned are only usable on PCs...
Smithcraft
Post by Smithcraft » Fri Jun 01, 2012 1:40 am
I'm pretty certain that both are usable in OS X.
I know tsmuxer is usable in OS X, and if Romansh is who I think he is, then I'm sure that mkvextract would work in OS X.
SC
setarip_old
Post by setarip_old » Tue Jun 12, 2012 3:39 pm
I am mistaken. My apologies...
