The Thing (1982) 4K disc not detected
potaattomuusi
Post by potaattomuusi »
Hi, just tried to rip The Thing but the disc is not detected by makemkv nor windows. I have ripped over 100 UHD movies successfully so I'm not sure what the problem is. Other discs still work.
DEBUG: Code 3 at "oE"zw-C#/T}N <+[}~oXu$):29395310
Hopefully someone wiser than me can help. Thanks!
Re: The Thing (1982) 4K disc not detected
potaattomuusi wrote: Tue Oct 20, 2026 5:19 pm Hi, just tried to rip The Thing but the disc is not detected by makemkv nor windows. I have ripped over 100 UHD movies successfully so I'm not sure what the problem is. Other discs still work.
You can start by cleaning the disc.
potaattomuusi
MartyMcNuts wrote: Tue Oct 20, 2026 9:29 pm
I already did that. Also I just bought it new so there is no scratches or other defects.
potaattomuusi wrote: Tue Oct 20, 2026 9:41 pm
A lot of the time, UHD discs require cleaning because they often have an invisible layer of film on them from the manufacturing process, therefore is very common for brand new discs.
It's possible it is a bad disc. Can you try it in another drive?
Once the disc is seen in windows explorer, you can then open the MakeMKV application.
potaattomuusi
I had the chance to try the disc with a xbox one s and it worked normally. Still windows is not recognizing it with my drive and like I said other discs still work. I'm stumped...
