Verbatim 43888 Firmware 1.05 Don't Flashing
Eze2kiel
Post by Eze2kiel » Fri Oct 16, 2026 10:55 pm
Hello everyone.
I have a recently acquired Verbatim 43888.
Here is the log from MakeMKV:
OS device name: J:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ----
I'm following the steps to flash it, but I keep encountering various errors—for example:
Internal error 0x83000001
Command Procedure error code 0x82052400
Could someone provide some guidance on how to flash it correctly?
Re: Verbatim 43888 Firmware 1.05 Don't Flashing
Post by MartyMcNuts » Sat Oct 17, 2026 12:55 am
Eze2kiel wrote: Fri Oct 16, 2026 10:55 pm Hello everyone.
OS device name: J:
Revision: 1.05
Serial number: ----
What are you using to flash it? A flashing tool or command line? If the latter, what is the command you are using?
Also note, you should not use MakeMKV v2.0.0 for flashing. Use MakeMKV v1.18.4.
Eze2kiel
Post by Eze2kiel » Sat Oct 17, 2026 1:09 am
MartyMcNuts wrote: Sat Oct 17, 2026 12:55 am
OS device name: J:
Revision: 1.05
Serial number: ----
I used command line.
Later see the Thread viewtopic.php?t=22896 and finally flashing correctly!.
OS device name: J:
Revision: 1.03
Serial number: -----
Firmware version: 1.03
Many thanks!.
