i-void-warranties
Post
by i-void-warranties » Sat Oct 29, 2011 4:01 pm
I get a bunch of errors while trying to process 'Captain American - The First Avenger':
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 18878754816, attempting to work around
Failed to save title 0 to file C:/temp/ripped/CA/MKV/title00.mkv
0 titles saved, 1 failed
Is there something wrong with the Bluray files that was ripped?
setarip_old
Post
by setarip_old » Sat Oct 29, 2011 5:02 pm
Hi!
It's likely a dirty or physically damaged disc.
Try cleaning the disc...
slarty55
Post
by slarty55 » Thu May 24, 2012 12:32 am
i don't think it's a bad disk... i just had the exact same error "'/BDMV/STREAM/00800.m2ts' at offset '2098550784'" on 2 completely different disks of Captain America.
Anyone else ABLE to rip Captain America with MakeMKV? I bet not.
crowfax
Post
by crowfax » Thu May 24, 2012 3:02 am
You bet wrong. Worked fine for me.
The disc is damaged, if it's happened with more than one disc, you have a bunch of bad discs.
Or your drive might be dying.
The error message literally means your drive can't read the disc. You can make whatever you want from that.
Romansh
Post
by Romansh » Thu May 24, 2012 10:42 pm
You could always try to do a decrypted
full disc backup and create the MKV file from that backup.
In theory it should be unnecessary, but I've occasionally had "invalid or corrupt at offset" errors when doing disc -> MKV, whereas disc -> backup -> MKV produced no errors of any kind (i.e. not even hash check errors).
