i purposely flashed my X12U drive with a SAT Family of RS9001 with version 1.06, to become a BDR-212U with version 1.04 and SAT Family of RS8F01.
Successfully done..And LibreDrive is enabled!!
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.04
Serial number: BFDL048791WL
Firmware date: 2022-12-20
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.04/ID58
LibreDrive for Pioneer drives
Yethidran
And now i just reflased it back to a X12U with a SAT family of RS9001!! And as you can see its LibreDrive Enabled too!!
Hehehehe!!!
MattJackson's Flasher is fun to play it!! Hehehehe!!!!
OS device name: F:
Product: BD-RW BDR-X12U
Revision: 1.06
Drive platform: RS9001
Firmware name: PIONEER BDR-X12T
Firmware version: 1.06/ID43
Hehehehe!!!
OS device name: F:
Revision: 1.06
Yethidran
within just 10Mins i can just flash to this and that and back and forth.. Hehehehe!!
androgenix
Thanks for the softwareCoopervid wrote: Thu Oct 15, 2026 10:23 amPM sent for flashing to 1.02 which is Libredrive and UHD capable.androgenix wrote: Thu Oct 15, 2026 9:03 am Apologies if already asked and answered elsewhere (I couldn't find with a search).
I have Pioneer BDR-212UHBK (from Japan) with following MakeMkv info:
OS device name: G:
Revision: 1.04
Serial number: CCDL006904WL
Highest AACS version: 82
Drive platform: Pioneer RS8F01
Firmware version: ID83
Same either way with USB or direct SATA connection.
I tried submitting the firmware .tgz to MakeMkv support some time ago but no change since.
Any way to get this LibreDrive enabled? With UHD support?
However, it is failing with the below messages. I have tried multiple times as Administrator, antivirus off. Drive is left in kernel mode, but if repowered the original MakeMkv information is restored to apparently no update is made. Note theis is a BDR-212UHBK not BDR-212UBK or BDR-S12U. I have repeated the MakeMkv information below for reference. Thanks
C:\Users\Andrew\Downloads\8F01_windows_x64>flash.bat
Kernel: C:\Users\Andrew\Downloads\8F01_windows_x64\S8F01430.100
Firmware: C:\Users\Andrew\Downloads\8F01_windows_x64\S8F01431.102
Looking for drives...
Available drives:
[1] PIONEER BD-RW BDR-212U (G)
Which drive do you want to flash? (1-1): 1
About to flash:
Drive: PIONEER BD-RW BDR-212U (G)
WARNING: A wrong or interrupted flash can permanently damage the drive.
Do not unplug the drive or turn off the computer while flashing.
Type YES to continue: YES
Flashing PIONEER BD-RW BDR-212U
Drive ............ PIONEER BD-RW BDR-212U / 1.04 / SAT 8F01 / ID83
Firmware file .... S8F01431.102 / PIONEER BD-RW BDR-S12U / 1.02 (2022-03-07) / SAT 8F01 / ID43
Kernel file ...... S8F01430.100 / PIONEER BD-RW BDR-S12U / 1.00 (2019-01-10) / SAT 8F01 / ID43
Don't unplug the drive or switch it off until this is done.
Checking the drive...
Making sure the drive is in kernel mode...
The drive is in kernel mode.
Kernel upload .... [#####################################---] 93.4 %[!] SCSI command failed: status 0x02 (CHECK_CONDITION), sense key 0x04, ASC/ASCQ 0x4c/0x02
If the flash has been started, don't unplug the drive: it may be in kernel mode. Run the command again to retry.
Flashing FAILED (exit code 1).
Press Enter to close this window:
OS device name: G:
Revision: 1.04
Yethidran
Why dont you try MattJackson's Flasher? its so simple to use too...
New version sent. Maybe I had an older one uploaded. Try the new one.androgenix wrote: Thu Oct 15, 2026 5:25 pmThanks for the softwareCoopervid wrote: Thu Oct 15, 2026 10:23 amPM sent for flashing to 1.02 which is Libredrive and UHD capable.androgenix wrote: Thu Oct 15, 2026 9:03 am Apologies if already asked and answered elsewhere (I couldn't find with a search).
OS device name: G:
Revision: 1.04
Available drives:
About to flash:
OS device name: G:
Revision: 1.04
See guide we have flasher that is fully tested on theseandrogenix wrote: Thu Oct 15, 2026 9:03 am Apologies if already asked and answered elsewhere (I couldn't find with a search).
OS device name: G:
Revision: 1.04
androgenix
Thank you, this one worked:Coopervid wrote: Thu Oct 15, 2026 6:38 pmNew version sent. Maybe I had an older one uploaded. Try the new one.androgenix wrote: Thu Oct 15, 2026 5:25 pmThanks for the softwareCoopervid wrote: Thu Oct 15, 2026 10:23 am
Available drives:
About to flash:
OS device name: G:
Revision: 1.04
OS device name: G:
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Firmware version: 1.02/ID43
justinbloom
I apologize. I am a complete noob when it comes to LibreDrive. I worry this topic has already been mentioned multiple times in here, but I still don't understand what to do. I see notes about flashing, and I have seen some notes that seem to imply a flash is not needed and that the firmware is loaded dynamically. I have a BDR-212M and I want to use LibreDrive. However, I can't figure out how to get it to work. I am on Linux and I was running the flatpak version, but have since tried to compile the code myself. I can't figure out what to do. I can play discs in VLC, but when I try to bring up MakeMKV it never loads the disc. This is my info:
OS device name: /dev/sr0
Product: BD-RW BDR-212M
Revision: 1.00
Serial number: TGDL010556WL
Firmware date: 2019-01-10
Highest AACS version: 76
Firmware version: GENE
I tried to ask Gemini and it suggested downgrading MakeMKV to 1.18.4. It also found an sdf.bin file that I put into ~/.var/app/com.makemkv..makeMKV/config/mkv. However neither of these make a difference. MakeMKV still seems to look up during initialization.
Please let me know what to do. I again apologize for duplicated issues.
Revision: 1.00
See guide below you just email me for it please don't spam this all aroundjustinbloom wrote: Tue Nov 10, 2026 7:43 am I apologize. I am a complete noob when it comes to LibreDrive. I worry this topic has already been mentioned multiple times in here, but I still don't understand what to do. I see notes about flashing, and I have seen some notes that seem to imply a flash is not needed and that the firmware is loaded dynamically. I have a BDR-212M and I want to use LibreDrive. However, I can't figure out how to get it to work. I am on Linux and I was running the flatpak version, but have since tried to compile the code myself. I can't figure out what to do. I can play discs in VLC, but when I try to bring up MakeMKV it never loads the disc. This is my info:
Revision: 1.00
PSA now most Pioneers can now be flashed even 12/22+ ones
if your pioneer UHD drive does not work send your makemkv drive info here do not send any attachments or images: Billycar5924@gmail.com
send an email with this exact subject line: Pioneer FW + Flasher Request
not doing so will delay your fw do not add anything to it
