No green button
psychdude
No green button
Post by psychdude » Thu Oct 15, 2026 12:43 pm
I recently downloaded MakeMKV and purchased a key. In the past I have used the program with success. Now, I’m on pop os cosmic now but in the past Ubuntu and Mac OS. I purchased an external Libre blu ray drive from someone on this forum. When I load a dvd, it gives me an option to back up to an iso. When I insert a blu ray, it allows me to create the backup and folders for the blu ray. However, there is no big green screen to makemkv. I used this program in the past, so I know what the big green button is, but it no longer is there. I can change the program properties but don’t want to mess things up or make it worse. Can you guys help?
Sayaka
Re: No green button
Post by Sayaka » Thu Oct 15, 2026 3:01 pm
First of all, you probably should not use version 2.0.0 unless it somehow enables you to purchase a key, and even then, you should still downgrade afterwards. This latest version is buggy.
You should use 1.18.4 on Windows, Linux, and Mac, the only exception being when you use Linux and want to flash/dump a firmware or when you want to set the speed of a Pioneer drive to Performance, in that case you should downgrade all the way back to makemkv-bin-1.17.6 and upgrade back to 1.18.4 afterwards.
I don't know about MakeMKV 2.0.0, but with MakeMKV 1.18.4 there are two buttons with green arrows, namely the Backup button (when loading a disc or ISO file into MakeMKV), and the Save Selected Titles button (after a disc or ISO file has been opened).
This is the expected behavior. MakeMKV does not make Blu-ray ISOs (with UDF 2.50). If you would like to create an ISO file for a Blu-ray disc, you should use another program. Generally people use IMGBurn (with WINE if needed), however I've also heard that on Linux, enabling LibreDrive with MakeMKV and then making an ISO file with dd is also an option.
SamuriHL wrote: Mon Apr 22, 2024 12:35 am Enable LibreDrive by opening the disc to the title selection screen in MakeMKV.
Use DD to create an ISO from the disc
sudo dd if=/dev/cdrom of=/some/folder/iso_name_here.iso
Obviously you'll have to replace the dev device with the dev device of your UHD drive and the folder path and ISO name but it'll work.
Henkjan
Re: No green button
Post by Henkjan » Thu Oct 15, 2026 8:49 pm
Sayaka wrote: Thu Oct 15, 2026 3:01 pm You should use 1.18.4
where can I download that? can't seem to find it
I have 1.18.3 still on my harddrive (now using 2.0.0)
Sayaka
Re: No green button
Post by Sayaka » Fri Oct 16, 2026 3:31 pm
MannyDanny
Re: No green button
Post by MannyDanny » Mon Oct 26, 2026 12:52 pm
Sayaka wrote: Thu Oct 15, 2026 3:01 pm downgrade all the way back to makemkv-bin-1.17.6
I, for performance reasons am also using v1.17.7 and intend to stay there, unless a newer version does not have the performance issues anymore.
I use the dockerized version, which is the most comfortable one for me, when ripping on Linux per WebVNC
But weird enough mine (for Windows I use v2.0.0) reports this, when I click on "Info":
Linux reports:
gwhitcombe71
Re: No green button
Post by gwhitcombe71 » Wed Oct 28, 2026 5:51 pm
had a similar thing last year when i updated makemkv on my old laptop without thinking... ripped my whole Only Fools and Horses box set the night before and it was fine, then the next batch crawled along at about half the speed (took alot longer than it should have, i was out in the garage with the Defender and kept popping back in to check it). i reckon i spent an evening digging around old versions before i found one that behaved, and ive just left it on that one since. never did work out what changed, to be fair, dont think i looked that hard 🙂
