Knowing 2008: ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK
MatthiasHannover
Post by MatthiasHannover » Wed May 23, 2012 4:08 pm
I have a problem in reading the blue ray: "Knowing 2008"
Update: The disk is a commercial version and the protection seems to be AACS v14.
Update: I tried it again and now it seems to be that it is working. The drive tries to read several time on the same track and the error is also displayed but one can press the Convert button afterwards and it seems to work. I'll let you know if some other will come up.
Thanks, Matthias
The debug output looks like this:
001003:0020 DEBUG: Code 2 at v$^VMBj(3N 8%`Q':121268719
001003:0020 DEBUG: Code 101016576 at qvQ*ZyYt$#%*UlBjV+:213132100
001003:0020 DEBUG: Code 101016576 at qvQ*ZyYt$#%*UlBjV+:29393930
002003:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' trat auf w?hrend des Auslesens von 'BD-RE HL-DT-ST BD-RE BH08LS20 2.00' bei Offset '24960301056'
Question: Is the disk broken? Or is this a new way of copy protection?
Best regards,
Matthias
