Public KeyDB Disc Submissions
oddzilla
Post by oddzilla » Thu Oct 15, 2026 2:47 am
Project Hail Mary - 1.43 Variable Aspect Ratio UHD - 4K UHD TGZ Dump File
Disc type: UHD
Disc ID: FA192C616A3848BEFA7BCD256DC63D30007D3ADE Oops, I was incorrect on the Disc ID. CORRECTING, just used KeyDB Assistant. Should be: 0xB0BDF82DBB6C15289660B59DC2C323FE5F58C305
Disc dump filename: MKB20_v82_Project_Hail_Mary_6AE9
Drive: ASUS_BW-16D1HT
Drive firmware: 3.02
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/1-j_B8W ... sp=sharing
MKB_RO Link: https://drive.google.com/file/d/1wOFh5n ... sp=sharing
I hope I'm doing this right and didn't fumble the disc ID. I saw another PHM variable aspect ratio disc, but the updated keydb didn't work and mine seems to have a different number on appended to it.
wellwelllwell
Post by wellwelllwell » Thu Oct 15, 2026 2:53 am
wellwelllwell wrote: Wed Oct 14, 2026 7:14 am Disc type: UHD
Disc ID: 0x2282CC41AA0E254C7FB9A7A96C726D16A213E7C0
Disc dump filename: MKB20_v76_Touch_of_Evil_Theatrical_Cut_53CD
Drive: PIONEER BDR-XS06
Drive firmware: 1.11/ID69
MKB_RO.inf link: https://drive.google.com/file/d/1YDobAq ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1NaGji4 ... sp=sharing
Here is the MKB_RO.inf Link: https://drive.google.com/file/d/1idh-qN ... sp=sharing
I think it was some other encryption program or similar giving me issues as it took a few tries and what it'd show is just "Files Ready to Be Written To Disc"
EDIT: I did a ton of testing and it will properly read the disc and show the folders only if I plug the reader in and the disc is the first one read.
Any subsequent reads after will have it read as a generic BDR drive only showing ""Files Ready to Be Written To Disc" in the disc itself.
Maybe its a Pioneer specific think I dunno but now I know the issue and future dumps should be spotless.
keydb_helper
Post by keydb_helper » Thu Oct 15, 2026 3:11 am
wellwelllwell wrote: Thu Oct 15, 2026 2:53 am Here is the MKB_RO.inf Link: ...
Thanks for following up. Your disc has been added to the public keydb.
wellwelllwell wrote: Thu Oct 15, 2026 2:53 am I think it was some other encryption program or similar giving me issues as it took a few tries and what it'd show is just "Files Ready to Be Written To Disc"
It sounds like a quirky behaviour but it almost seems consistent with Windows creating a desktop.ini file when first browsing the disc structure and then offering to write that pending file on subsequent interactions. I would still expect the original files to be visible though.
Which version of Windows are you using? And do you have any specific disc burning applications like the Nero suite or any kind of packet-burning software?
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
wellwelllwell
Post by wellwelllwell » Thu Oct 15, 2026 3:28 am
keydb_helper wrote: Thu Oct 15, 2026 3:11 am
Its Windows 11 24H2 and I have 0 disc burning or packet burning software.
The closest I have to that is Balena Etcher and that's it.
Post by MartyMcNuts » Thu Oct 15, 2026 5:20 am
wellwelllwell wrote: Thu Oct 15, 2026 3:28 am
You might want to promptly update your Windows! I believe there's only a few days left to update from 24H2. 26H2 has been around for a couple of weeks now.
cjw73
Post by cjw73 » Thu Oct 15, 2026 11:12 am
Blades Of The Guardians UHD
Disc ID: 6396BC80CB2892A1A8C5436661F0E5F909107604
Disc type: UHD
Disc dump filename: MKB20_v82_BLADES_OF_THE_GUARDIANS_E154.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Disc dump link: https://drive.proton.me/urls/JD8T77W8Q0#FdfAkovRkn8d
also, i noticed the template was updated, does it make it harder if i don't do the MKB_RO.inf link also ? will include it if it makes it easier for you... thanks for all the work you do :)
truebeliever61
Post by truebeliever61 » Fri Oct 16, 2026 5:05 am
Legend of the White Dragon
Disc type:UHD
Disc ID:0xE301723AFE0360E670008D588142AB2D8EAD22DB
Disc dump filename:MKB20_v82_Legend_of_the_white_dragon_9146
Drive:BD-RE BD-RE WH16NS60
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1piApP1 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1M1uvor ... sp=sharing
keydb_helper
Post by keydb_helper » Fri Oct 16, 2026 2:48 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_BLADES_OF_THE_GUARDIANS_E154
*MKB20_v82_Evil_Dead_Burn_C0A8
*MKB20_v82_Legend_of_the_white_dragon_9146
cjw73 wrote: Thu Oct 15, 2026 11:12 am also, i noticed the template was updated, does it make it harder if i don't do the MKB_RO.inf link also ? will include it if it makes it easier for you... thanks for all the work you do :)
Hey cjw73, if a UHD disc dump file is less than 3MB in size it won't include the full MKB_RO.inf file and this means that there is a chance the dump file will not be useful to the public keydb. These partial/incomplete disc dumps are the reason for the additional file link in the submission template. Most folks aren't interested in the technicalities of what is required under which circumstance, and that is fair enough, so I provide only a single template with no qualifiers or conditional inclusions.
Disc dump files in the 3-5MB range, such as your latest disc, should always be usable as they include the full MKB_RO.inf file.
As long as you include the full MKB_RO.inf file when it is not already present in the disc dump file I don't mind if it is otherwise omitted.
If you aren't sure whether to include the MKB_RO.inf file, you can just look at the last digit of the 4 character MakeMKV disc variant. If it is even (0,2,4,6,8,0xA,0xC,0xE) then the full MKB_RO.inf file is already contained in the disc dump file:
  • MKB20_v77_The_legend_of_sealed_book_F000.tgz
  • MKB20_v77_CAUGHT_STEALING_3002.tgz
  • MKB20_v82_Patriot,_The_-_Extended_Version_5104.tgz
  • MKB20_v77_PLATINUM_BLONDE_6006.tgz
  • MKB20_v82_BODY_HEAT_6008.tgz
  • MKB20_v82_Perfect_Blue_400A.tgz
  • MKB20_v77_Zootopia_2_180C.tgz
  • MKB20_v77_BOHACHI_BUSHIDO_450E.tgz
But if the final digit is odd (1,3,5,7,9,0xB,0xD,0xF) then the full MKB_RO.inf file should be supplied in addition to the disc dump file:
  • MKB20_v61_Arrival_2001.tgz
  • MKB20_v82_CIN_026_At_Close_Range_B203.tgz
  • MKB20_v65_The_Matrix_Revolutions_F305.tgz
  • MKB20_v77_Obi-Wan_Kenobi-_The_Complete_Series_Disc_2_B307.tgz
  • MKB20_v77_Godzilla_(1998)_8209.tgz
  • MKB20_v82_Eddington_1C0B.tgz
  • MKB20_v61_MARVEL'S_GUARDIANS_OF_THE_GALAXY_VOL_2_320D.tgz
  • MKB20_v77_A_Nightmare_on_Elm_Street_410F.tgz
If you happen to come across a partial disc dump file it is also an option to replace the 56 byte stub MKB_RO.inf with the full, multi-megabyte MKB_RO.inf file from the disc via a tool like 7-zip. This is appreciated but not essential.
KeyDB Priority List
Whitetail_Trucks
Post by Whitetail_Trucks » Fri Oct 16, 2026 4:11 pm
Indiana Jones and Raiders of the Lost Ark
Disc type: UHD
Disc ID: 0x1A2EB02619F0A2D352FF7531601B7F940224EB8A
Disc dump filename: MKB20_v76_Indiana_Jones_and_the_Raiders_of_the_Lost_Ark_D8C1.tgz
Drive: Pioneer BD-RW BDR-211M
Drive firmware: 1.53
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://litter.catbox.moe/sqw4qy.zip
Disc dump link: https://litter.catbox.moe/lavnei.tgz
Last edited by Whitetail_Trucks on Fri Oct 16, 2026 4:24 pm, edited 3 times in total.
Whitetail_Trucks
Post by Whitetail_Trucks » Fri Oct 16, 2026 4:13 pm
Dune - Part 1
Disc type: UHD
Disc ID: 0x968267CBFC6949E8D34A916EC1C9DB715E02F8E3
Disc dump filename: MKB20_v76_Dune_5C2B.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://litter.catbox.moe/8egplk.zip
Disc dump link: https://litter.catbox.moe/sd0kcp.tgz
wellwelllwell
Post by wellwelllwell » Fri Oct 16, 2026 4:34 pm
MartyMcNuts wrote: Thu Oct 15, 2026 5:20 am
Oh I definitely want to update but it looks like I'll have to force it as its not automatically asking me to.
ScoobyMKV
Post by ScoobyMKV » Fri Oct 16, 2026 4:39 pm
Submission for "PREY" UHD disc dated 2023-09-01
Disc type: UHD
Disc ID: 0x4F40995117B66CE61B0B6578158CD2B0E4D956FC
Disc dump filename: MKB20_v77_PREY_0735.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
Is your MKB_RO.inf file size at least 2MB? Yes
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1TqxGpQ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1TA-cvi ... sp=sharing
aeroJ
Post by aeroJ » Sat Oct 17, 2026 4:16 am
Hi, I have three more dump files here:
Disc type: UHD
Disc ID: 0x1737a1ba805e70e7efc8d80f31cccd6b3c4e3938
Disc dump filename: MKB20_v82_Stranger_Things-_Season_2_Disc_2_4B72.tgz
Drive: HL-DT-ST BD-RE BU40N
Drive firmware: 1.00
Disc dump link: https://drive.google.com/file/d/1GBnN7J ... share_link
Disc type: UHD
Disc ID: 0xdeb776fd5aa69bfe5cd83852113bf75ca8ead870
Disc dump filename: MKB20_v82_Stranger_Things-_Season_4_Disc_3_BAE8.tgz
Disc dump link: https://drive.google.com/file/d/1kBSjhS ... sp=sharing
Disc type: UHD
Disc ID: 0x9c543806dcd9a7f040dfe6402a1a25fa9242642b
Disc dump filename: MKB20_v82_Stranger_Things-_Season_5_Disc_2_423A.tgz
Disc dump link: https://drive.google.com/file/d/1XKDPms ... sp=sharing
keydb_helper
Post by keydb_helper » Sat Oct 17, 2026 6:12 am
MKB20_v76_Dune_5C2B
*MKB20_v77_PREY_0735
*MKB20_v82_HAROLD_AND_MAUDE_D750
*MKB20_v82_Ryans_Daughter_D1_UHD_EA78
*MKB20_v82_Ryans_Daughter_D2_UHD_398E
KeyDB Priority List
ScoobyMKV
Post by ScoobyMKV » Sat Oct 17, 2026 11:11 am
Thanks for this latest batch of updates! :D
