Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
392iou wrote: Fri Oct 02, 2026 3:46 pm Can I get a PM for what’s needed for this drive?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DGDL056286WL
Firmware date: 2022-03-16
Bus encryption flags: 13|
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.02/ID61
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Hucz89
Post by Hucz89 »
Coopervid wrote: Sun Mar 10, 2024 8:33 pm Send me a PM
Original out of the box Makemkv info:
Product: BD-RW BDR-212BK
Revision: 1.04
Firmware date: 2022-12-20
Firmware version: ID81
Current firmware that i have flashed to the drive:
OS device name: E:
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: DCDL049540WL
Firmware date: 2022-03-07
Highest AACS version: 25
Drive platform: RS8F01
Firmware version: 1.02/ID43
I'm struggling to get my drive to read any UHD discs. It's a legit drive, bought new, it's BDR-212DBK on the sticker, MFD. in April 2022 on sticker (flasher info says May 2024), and it reads and dumps everything perfectly fine except UHD discs (i have tried many different ones, no luck, drive just spins up a few times, and fails to read a UHD disc). I have cleaned the lasers several times, and ensured the rails glide properly. My enclosure provides USB3 and 3 amps of AC power, which is enough to power the drive.
Head scratcher for sure!
Hucz89
Post by Hucz89 »
Figured it out! My drive's default reading is Quiet Mode, so I changed it to enable High Speed reading, and it now reads UHD discs perfectly!
Yethidran
Post by Yethidran »
Interesting find, about the (Quiet Mode to High Speed Reading Thingy) i will also do that change for all my existing drives i have.
thanks buddy! Cheers!!
Hucz89
Post by Hucz89 »
Yethidran wrote: Thu Oct 15, 2026 1:21 am Interesting find, about the (Quiet Mode to High Speed Reading Thingy) i will also do that change for all my existing drives i have.
Unfortunately, it only worked for the two UHD i tried, but after that, no luck, even with the two discs I had success with. So it didn't quite take sadly.
Yethidran
Post by Yethidran »
yes, i do have 2 sets of the X12U drives that can only read cd's.. the laserhead is dead for 4K and blurays.. i use these 2 drives as guinea pigs now for testing out firmware flashing .. Hehehehe!!
i have opened them up and cleaned the laserheads numerous times, and also played with the pot screw too, i even changed the rubber pulley belt as i bought 100 pieces extra of that rubber pulley belt... but nothing works for getting the laserhead back to life.. Can only flash firmware for tests.. Hehehehe!!!
