Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Bailzer01
Re: Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Post by Bailzer01 »
Currently looking for a pre flashed drive. I have received 3 fake BP50NB40s from different sellers on eBay. I’ve even tried 2 BU40N’s from Amazon however they came very used and not well taken care of. I’m honestly tired of the headache of trying to flash, or even if the drive is real. I’m new to 4k ripping and am eager to learn. If anyone sells pre flashed drives for a fair price please let me know! I’m also interested in switching gears from the external slim lines entirely and instead using a Pioneer WH16NS40.
Bailzer01 wrote: Wed Oct 14, 2026 9:20 pm Currently looking for a pre flashed drive. I have received 3 fake BP50NB40s from different sellers on eBay. I’ve even tried 2 BU40N’s from Amazon however they came very used and not well taken care of. I’m honestly tired of the headache of trying to flash, or even if the drive is real. I’m new to 4k ripping and am eager to learn. If anyone sells pre flashed drives for a fair price please let me know! I’m also interested in switching gears from the external slim lines entirely and instead using a Pioneer WH16NS40.
Please post the seller and what the drive looks like here
viewtopic.php?t=42623
Bailzer01
Post by Bailzer01 »
Posted there. Thank you :)
Hucz89
Post by Hucz89 »
Figured it out! My drive's default reading setting was Quiet Mode, so I changed it to enable High Speed reading, and it now reads UHD discs perfectly!
flintysmasher
Post by flintysmasher »
Two questions for flashing on Mac:
Drive information:
Model: Buffalo PUS6U3B (BU40N inside)
Revision: BN14
Drive Platform: MT1959
Questions:
  • Is HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin from the "all you need firmware pack" the correct firmware to flash?
  • Is makemkv 1.17.7 still the recommended version for flashing? (I've been ripping on 2.0.0.)
Thank you!
Yethidran
Post by Yethidran »
Interesting find, about the (Quiet Mode to High Speed Reading Thingy) i will also do that change for all my existing drives i have.
thanks buddy! Cheers!!
Sayaka
Post by Sayaka »
flintysmasher wrote: Thu Oct 15, 2026 1:38 am Two questions for flashing on Mac:
Drive information:
Revision: BN14
Questions:
Thank you!
Yes to the first question. You will need to use rawflash enc. As for the second question, using 1.17.6 and 1.17.7 for flashing/dumping is only recommended for Linux users (due to later Linux versions having a broken firmware tool). For Mac (and Windows) users, I personally recommend 1.18.4. While flashing should hopefully work fine with 2.0.0, version 2.0.0 is known to have bugs, and a bug occurring during the flashing process would be really bad. I wouldn't want to risk it with 2.0.0, so I would just use 1.18.4 on Mac, personally.
Hucz89
Post by Hucz89 »
Yethidran wrote: Thu Oct 15, 2026 2:02 am Interesting find, about the (Quiet Mode to High Speed Reading Thingy) i will also do that change for all my existing drives i have.
Alas, it worked only twice, and then it stopped reading UHD discs again, so I think the high speed setting was a red herring. I was making micro adjustments to the pot screw inside, it has helped speed up reading stand blu rays, but still no luck getting a UHD disc to read (i mustve just got lucky those two times). dang!
Hucz89 wrote: Thu Oct 15, 2026 7:09 am
... im so tired of the pot screw idea's where do you guys think this is it does not exist on modern LG drives and i dont think i exists on modern pioneer drives please stop posting false info
Hucz89
Post by Hucz89 »
Billycar11 wrote: Thu Oct 15, 2026 7:11 am
Whatever, it was the heigh adjusting screw along the rail... at least I'm trying to fix it
Hucz89 wrote: Thu Oct 15, 2026 7:26 am Whatever, it was the heigh adjusting screw along the rail... at least I'm trying to fix it
again thats not a thing...
i have taken apart many of these drives to repair them
i feel like your asking ai or something to guide you through this and it knows nothing and you have no experience with these drives and dont understand how they work internally
and thats not to insult you but we cant have bad info like this posted here as it misleads others thinking they should start turning some screw in the drive to fix it... and this is not the first time i have seen this pop up
Hucz89
Post by Hucz89 »
It is a thing. There are three height adjusting screws where the two rails are that the laser assembly glides along, adjusting them changes the distance of the laser to the disc's surface.
emalup359 wrote:Fri Oct 16, 2026 10:49 pm
I don't think I can PM anyone yet, since I just made this user, but does BDRFlash++ only work for a pure Pioneer drive, or does it work for a Pioneer drive inside an ASUS enclosure as well? This is the one I have:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: E113/ID76
all you have to do is send an email as the guide describes long as you send it with the exact subject line "Pioneer FW + Flasher Request" without the quotes
you will get a flasher and fw within 5 min's 24/7 we have it so some will always answer
emalup359
Post by emalup359 »
Billycar11 wrote: Sat Oct 17, 2026 6:17 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
I didn't post in this thread, so I don't know why you are quoting me in this thread.
To anyone else, my original post can be found here: viewtopic.php?p=207042#p207042
NoMoreSorry wrote: Mon Jun 15, 2026 6:14 pm Hello, I am new here, wondering if my drive can be flashed to UHD. Any help would be greatly appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: DDDL291769WL
Firmware date: 2023-04-20
Drive platform: RS8511
Firmware version: E102/ID26
This drive is now flashable
Please see guide for how to get the fw and flasher
