v2.0.0 missing file
Hydisc
v2.0.0 missing file
#1 Post by Hydisc » Tue Oct 13, 2026 3:24 pm
Issue after loading the version v2.0.0 and using the SDFtool flasher v1.3.6 or v1.3.5. Get an error that the SDFtool64 file cannot be found in the MakeMKV folder loaded on C: drive. I found that this file is missing. Went and loaded v1.18.3 and v1.18.4 and see that this file does load from either of those versions. I saved the file, reloaded v2.0.0 and copied the SDFtool64.exe file into the folder.
