hidden titles on DVD? is that possible?
ssybesma
#1 Post by ssybesma » Sun Oct 11, 2026 10:12 pm
I used MakeMKV on my DVD "The Passion of the Christ" (English release) but it only found 4 substantial titles, two of 2 hrs 1 min 52 secs and and two of 2 hours 6 mins 32 secs. There were two other titles of under 20 seconds each. The titles with identical longer times appear to be exactly the same as well as the titles with identical shorter times.
All four appear to be the same when watched, with the shorter ones likely being the recut version (with 4 mins 40 secs of extreme graphic scenes cut out).
Basically two pairs of the exact same video.
The back of the DVD lists four special features:
1. Two versions (original and recut)
2. Audio commentary for original version
3. Biblical footnotes for original version
4. Music commentary for original version
I am not seeing 2, 3 and 4 at all.
Any ideas how to process this DVD so everything shows up?
ssybesma
UPDATE
#2 Post by ssybesma » Sun Oct 11, 2026 10:54 pm
Update: Titles 5 and 6 (never in the list) are not visible. This is after setting minimum title length to 0.
Using LibreDrive mode (v02.1 id=95C4500CE7CA)
Complex multiplex encountered - 16 cells and 7562 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (44 cell(s), 2:06:05)
Complex multiplex encountered - 16 cells and 7536 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #2 was added (44 cell(s), 2:01:27)
Title #3 was added (2 cell(s), 0:00:11)
Title #4 was added (2 cell(s), 0:00:13)
Title #7 was added (44 cell(s), 2:01:27)
Title #8 was added (44 cell(s), 2:06:05)
Re: hidden titles on DVD? is that possible?
#3 Post by d00zah » Sun Oct 11, 2026 11:19 pm
Under MakeMKV preferences > Protection tab > DVD structural protection removal method
Default mode is 'Auto'. Try any of the discrete modes... CellTrim, perhaps?
ssybesma
found what is going on
#4 Post by ssybesma » Mon Oct 12, 2026 5:29 am
There are no titles missing.
What is actually happening is that each of the 4 largest titles (each one by itself is the movie - 2 original and 2 recut) have 8 audio tracks, 7 of which are checked by default.
They are:
1. Aramaic
2. English (default used by all players and only possible one used by Roku Media Player if MKV includes all tracks)
3. Spanish - not checked by default
4. Descriptive audio (for the blind, presumably)
5. Commentary #1
6. Commentary #2
7. Commentary #3
8. Commentary #4
I found this out by playing the MKV file in Emby and VLC. If I wanted Roku Media Player to play each of the 4 commentaries, I would need to create 4 additional MKV files.
(Which is not worth the effort and a waste of disk space.)
BUT...that leaves me with a question. I understand the presence of two titles: one for the slightly larger original, and one for the slightly smaller recut. Why are there 2 of each?
I don't notice any difference between either pair of MKV files of the same size.
