I found this in amazon jp for cheap-ish (on amazon outlet). I saw this thread and figured it should at least work with libredrive but no other details.
And then there's this thread which has very similar model number, just differ by one letter "PUS" vs "PUV" but the rest seems suspiciously familiar. I went ahead and flashed with 1.03 using SDFtool and the BU-40N 1.03 firmware; the app says it's encrypted firmware hence the 1.03.
One flashing later (using the usb enclosure as is), it seems to be able to read UHD disc (only checked up to content listing in makemkv) and ripped a few blu-ray discs fine. I haven't tested burning yet.
Unfortunately I forgot to take note of the drive info before flasing but here it is after flashing. I think it's almost exactly the same as the one on PUS thread (just differing in serial number and firmware date).
OS device name: F:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.03
Serial number:
Highest AACS version: 82
Firmware version: 1.03
Buffalo BRXL-PUV6U3-BK/N
skl49
Re: Buffalo BRXL-PUV6U3-BK/N
Before flashing:
OS device name: H:
Revision: BN14
Serial number: Redacted
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
OS device name: H:
Revision: BN14
see guide below or email me or marty for an auto flasherskl49 wrote: Thu Feb 05, 2026 11:03 am Before flashing:
OS device name: H:
Revision: BN14
spindleBbq
This is a great find! The only difference between "PUS" vs "PUV" is that the former is bundled with blu-ray playback software while the latter is not.nanaya wrote: Mon Oct 13, 2025 11:43 am I found this in amazon jp for cheap-ish (on amazon outlet). I saw this thread and figured it should at least work with libredrive but no other details.
OS device name: F:
Revision: 1.03
Serial number:
