Asus BW-16D1X-U
Re: Asus BW-16D1X-U
funkywaddle wrote: Fri Sep 25, 2026 3:10 am
enc, not main?
I did finally get it to work. I had to downgrade to 1.17.7. It seemed to work alright. I'm currently making a mkv from a bluray disc. We'll see if it works.
Should I have done enc instead of main? Do I need to do it again?
yes had to be enc
movieman12345
Re: Asus BW-16D1X-U
Post by movieman12345 »
Just found this drive, will it be able to do 4kUHD out of the box? Can I flash it if not? I have seen conflicting reports online
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: QKDL141900WL
Firmware date: 2017-01-15
Highest AACS version: 81
Drive platform: RS8600
Firmware version: E102/ID76
OneDay
Re: Asus BW-16D1X-U
Post by OneDay »
movieman12345 wrote: Fri Oct 09, 2026 5:37 pm Just found this drive, will it be able to do 4kUHD out of the box? Can I flash it if not? I have seen conflicting reports online
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
You will need to cross flash it to Pioneer BDR-S11.
Re: Asus BW-16D1X-U
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
See guide below
Re: Asus BW-16D1X-U
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Are you on Linux ARM or x64? I need to know to send the appropriate flasher.
bob1273
Re: Asus BW-16D1X-U
Post by bob1273 »
Coopervid wrote: Tue Sep 15, 2026 9:02 pm
bob1273 wrote: Tue Sep 15, 2026 11:12 am Hey there,
so if I have a new ASUS BW-16D1X-U, which Firmware should I flash to - the LG WH16NS60 1.02MK ?
Thanks in advance
Post your Makemkv info as plain text.
OS device name: /dev/rdisk6
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLXPBJG0506
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
I want the best read/copy speed for DVDs and BluRays as well as some 4kuhds - Do I have to flash to enable LibreDrive and what's the best way to do so? Thanks for every help!
Re: Asus BW-16D1X-U
bob1273 wrote: Wed Oct 14, 2026 4:48 pm
Thanks in advance
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Flash WH16NS60 1.02 accorning to this thread:
viewtopic.php?t=19634
bob1273
Re: Asus BW-16D1X-U
Post by bob1273 »
Coopervid wrote: Wed Oct 14, 2026 5:47 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Thanks for the answer. Before I flash, I want to be sure about two things for my drive :
My firmware date shows as 2120-12-02. I assume this means it is a 2020 encrypted firmware, so I would use rawflash enc. Is that correct?
The guide says Asus drives should first go to Asus BW-16D1HT 3.10MK, while you recommended WH16NS60 1.02. Which one is safe for the BW-16D1X-U? I’m on macOS, so I would use makemkvcon with sdf.bin on 1.17.7. Is that fine, or is there a safer way?
Re: Asus BW-16D1X-U
Yes. All your assumptions are correct. A sidegrade to Asus 3.10 before flashing WH16NS58 is most likely the safest approach.
rabbatz
Re: Asus BW-16D1X-U
Post by rabbatz »
I'll get my BW-16D1X-U in a few days so i read a bit in this forum.
Reading this thread gives me the impression people are quite relaxed here 👍
Now to my question :
MovieManager12345 posted his mkv info saying drive platform is RS8600 for his BW-16D1X-U, not MT1959 as expected.
So I guess the drives in BW-16D1X-U can be from different manufacturers? Or is it possible to flash other wrong fw to get such results?
THNX in advance
Re: Asus BW-16D1X-U
rabbatz wrote: Thu Oct 15, 2026 10:33 pm I'll get my BW-16D1X-U in a few days so i read a bit in this forum.
THNX in advance
They can have either a Pioneer or LG drive inside the enclosure. Some lucky people get a Pioneer!
jcucurull
Re: Asus BW-16D1X-U
Post by jcucurull »
Coopervid wrote: Wed Oct 14, 2026 6:41 pm Yes. All your assumptions are correct. A sidegrade to Asus 3.10 before flashing WH16NS58 is most likely the safest approach.
And why the sidegrade to the Asus 3.10 (i.e. DE_ASUS_BW-16D1HT_3.10_MK) is not enough? Why is it needed the WH16NS60 1.02? Is there any improvement regarding the Asus one?
Re: Asus BW-16D1X-U
jcucurull wrote: Tue Oct 27, 2026 9:48 pm
no sleepbug on wh16ns60
gwhitcombe71
Re: Asus BW-16D1X-U
Post by gwhitcombe71 »
Billycar11 wrote:no sleepbug on wh16ns60
Billycar11, what's this sleepbug actually do though? Is it the drive dropping out when it idles mid-rip, or something else... (not come across it myself)
How did you first spot it, mate, just from the drive acting up or did you read about it somewhere?
Re: Asus BW-16D1X-U
gwhitcombe71 wrote: Fri Oct 30, 2026 4:10 pm
See guide for full discription
But if you leave a UHD disc idle for 2 mins and the drive spins down it will not spin backup
