Buffalo ext drive will not open after Firmware flash
Peabody111
Re: Buffalo ext drive will not open after Firmware flash
Post by Peabody111 »
I cant seem to locate the ASUS flash tool
zittrig
Post by zittrig »
Billycar11 wrote: Sat Oct 10, 2026 1:25 pm
zittrig wrote: Sat Oct 10, 2026 1:20 pm Check my post above then. Perhaps more luck with the modified ASUS flasher?
No that won't work you need recovery for this situation
Ok, thanks Billy. So there have to be another recovery solution.
Remember the longer this drive is on the wrong fw the more likely it is to be dead
Peabody111
Billycar11 wrote: Sat Oct 10, 2026 1:33 pm Remember the longer this drive is on the wrong fw the more likely it is to be dead
Its probably dead then :roll:
Peabody111 wrote: Sat Oct 10, 2026 1:34 pm
Still worth trying but leave it unplugged from power and USB when your not recovering it
zittrig
Post by zittrig »
For my understanding:
1. What does the recovery mode different to flash another firmware directly?
2. Why is a drive more likely dead in relation how long it runs with the wrong firmware? Installed is installed. Or what other technical aspects need to be considered here?
Sayaka
Post by Sayaka »
RECOVER/rawflash "main,nowait,nocheck,boot=[wrong boot ID]", aka "flash with fake boot ID", is much more powerful. You can do things with it that you can't do with a normal flash, such as crossflash a BP55EB40 without doing a bootloader flash/rawflash full beforehand, and it also allows you to recover a wrongly flashed drive such as this one (nowait,nocheck is also nice to have when the drive tray doesn't respond anymore). It is also, apparently, more dangerous than a normal flash if done wrong.
I believe it's because a slim firmware installed on a desktop drive (or the opposite ! especially the opposite) is dangerous. It interacts with the hardware in a way that a "correct" firmware wouldn't. Some people actually managed to set their slim drives on fire by flashing desktop firmware onto them, according to Mike.
Please give me a bit more time and I will post detailed instructions on the command line version very soon, which for some reason seems to work for some people when the SDFtool Flasher way fails.
Peabody111
Ok thanks for all the help . Truly appreciate
Sayaka
Post by Sayaka »
Could you please open a cmd.exe window or PowerShell window inside the folder where MakeMKV is installed and try this, please ?
(This one is courtesy of Billycar11 and his guide, it seems to work well.)
.\makemkvcon64.exe f --all-yes -d D: rawflash nocheck,boot="MT1959 Boot BU5 " -i "C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin"
or
.\makemkvcon64.exe f --all-yes -d D: rawflash "main,nowait,nocheck,boot=MT1959 Boot BU5 " -i "C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin"
if the first one fails.
Keep the space after BU5, it is not a typo. Also keep the quotes exactly as they are in both cases.
(Also, I suggest you flash with MakeMKV 1.18.4, not 2.0.0)
Peabody111
hopefully i am doing it correctly but it says on both Windows can not find....
Peabody111
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d D: rawflash nocheck,boot="MT1959 Boot BU5 " -i "C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin"
Input file not found -- C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin
Internal error 0x83000001
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d D: rawflash "main,nowait,nocheck,boot=MT1959 Boot BU5 " -i "C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin"
zittrig
Post by zittrig »
Peabody111 wrote: Sat Oct 10, 2026 5:08 pm PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d D: rawflash nocheck,boot="MT1959 Boot BU5 " -i "C:\replace-this-with-correct-firmware-path\DE_LG_WH16NS60_1.02_MK.bin"
You should "C:\replace-this-with-correct-firmware-path\" replace with the correct firmware path ;)
Peabody111
I’m lost
Peabody111
This above my pay grade
Peabody111
Thanks guys for trying to help . I’m just gonna buy a new one already jailbroke
