My XD05 is now a XD08U!!
Yethidran
Post by Yethidran »
this is my original XD05 readout.
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number: ...
Firmware date: 2014-04-02
Highest AACS version: 68
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21/ID69
Yethidran
Re: My XD05 is now a XD08U!!
Post by Yethidran »
then with Coopervids help i flashed it to become a XD06U.
OS device name: I:
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number: NFDL004706JP
Firmware date: 2017-06-22
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
Yethidran
Post by Yethidran »
and now with MattJackson's Flasher i have managed to flash it to a XD08U!! Wow is all i can say!!
OS device name: I:
Product: BD-RW BDR-XD08U
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 61
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID69
Yethidran
Post by Yethidran »
oh yes, my 1st post didnt show the "Serial Number" as proof..
so i will grab a screenshot of it with the serial number so all can see that it can be done.
OS device name: I:
Revision: 1.21
Yethidran
Post by Yethidran »
and yes, eventhough the XD08U firmware is in the "Dreaded End December 2022", i still can rip 4K UHD Discs!!
Yethidran
Post by Yethidran »
Anyway the link to download his free flasher i will attach it below.
https://freemkv.org/firmware/flash/
and to download firmwares the link is attached below.
https://freemkv.org/firmware/find/
remember to "Backup" and also "Dump" your current drives, and save on your desktop for easy access, if you ever need to use it.
and DONT unzip the firmware files.. just use that 1 Zipped file if u want to flash the drive.. that's the only "Glaring difference vs the Regular BDRFlash software where u need to copy/drag 2 files over into the flasher.
zittrig
Post by zittrig »
Ok, but the XD05 has a much older hardware than the XD08U (roundabout 8 years?) so I don't think, there are more advantages / changes than only the designation.
Yethidran
Post by Yethidran »
but i did see the option of "Pure Read Functionality now being able"
i might be wrong because i was too trigger happy to just flash it and forgot to check if the older one had that "Pure Read Funtionality Greyed out or highligted"
maybe those who have flashed their xd05 to a xd06u can confirm?
zittrig
Post by zittrig »
In don't know if the Pure Read function only software or also hardware based. Alone the laser technology is also much older with the XD05.
But that are only thought from someone who uses the drives only for 4k ripping. I don't use the other interesting functions of the Pioneer drives
consciously. Helps they for a smoother ripping?
Yethidran
Post by Yethidran »
"Pure Read Functionality, i believe is for Audiophiles use" i may be wrong, but i think i read about it in one of the pioneer doc's
