Hard Drive is now corrupt with access denied
Luminated67
#1 Post by Luminated67 » Fri Oct 09, 2026 8:12 am
I have been using the beta version for a month ripping movies to my hard drive and it ran out this morning so I downloaded the new version and despite not ripping any new movie to my hard drive the drive now says it's corrupt and access denied. Any advice would be most welcome because I have over 200 movies ripped to it and the thought over going through this again fills me with dread, in my recent file which lists about 20 movies done I can click on each and play them so the data seems to be fine but I can't seem to access the drive itself. Is there anyway of forcing the PC to run a check and fix possible corrupt files?
BTW I have a 22TB drive which has been separated into two 11TB halves and up to now I have been filling both sides with zero issues this has only happened when MakeMKV inforned me my old version was out of date and had to download the new version.
SamSpeexy
Re: Hard Drive is now corrupt with access denied
#2 Post by SamSpeexy » Fri Oct 09, 2026 3:44 pm
What is your OS?
If you're on windows, you could try hooking up your hard drive to a linux system and see if you can access it from there.
Luminated67
#3 Post by Luminated67 » Fri Oct 09, 2026 7:02 pm
SamSpeexy wrote: Fri Oct 09, 2026 3:44 pm What is your OS?
I have the guys that do our software system at work looking in to it but the weird thing is the other folders in the Hard drive can all be accessed apart for the movies folder so something there is the issue. Everything they are trying to sort it isn’t getting access to that folder, I’m now hoping that worst case is that they can wipe the drive to start over rather than the drive itself is screwed.
AstralWanderer
#4 Post by AstralWanderer » Sun Oct 11, 2026 5:34 pm
There are dozens of tools for checking hard drive health - if you're running Windows then try Hard Disk Sentinel (it monitors hard disk SMART statistics and has several options, destructive and non-destructive, for testing a hard disk - it's commercial software with a 30-day evaluation period). If you want to stick with free software, CrystalDiskInfo will report on SMART statistics only.
However if only one folder is inaccessible, this is more likely to be a filesystem fault - the most prudent step then is to take a full disk (image) backup before changing anything (having one would have saved you from this situation in the first place - remember that hard disks and SSDs will inevitably fail at some point) and then running chkdsk <drive letter> /f from the Command Prompt.
